2.5 n/a diesel fuel line size - Defender Source
Old August 18th, 2014, 04:05 PM
byrnecc's Avatar
byrnecc
Conor
1986 ex-mod 110
Couldn't find a definite answer, I think it's 5/16? Looking to replace some fuel lines around the filter
Old August 18th, 2014, 04:09 PM
The main lines are 3/8" nylon tubing. Some of the lines around the engine are 5/16" nylon tubing. I forget which ones. Standard nylon tubing is all you need. If you are using any of the stock barb style fitting, you need to very carefully heat the nylon to the point it becomes soft....and then insert.
Old August 18th, 2014, 04:56 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Size = 8mm
RDavisinVA
Old August 18th, 2014, 05:38 PM
byrnecc's Avatar
byrnecc
Conor
1986 ex-mod 110
trying to order off of mcmaster-carr, what should the inner and outer diameter be? Or a part # if that'd be easier
------ Follow up post added August 18th, 2014 03:42 PM ------
McCaster-Carr 5140K95 would that work? Would this be compatible with stock fittings?
Old August 18th, 2014, 05:45 PM
The numbers being quoted are the outer diameter. Normal 3/8" tubing is 1/4" ID and 5/16" is 0.233" ID. ID does not matter a whole lot.
Old August 18th, 2014, 05:48 PM
john, conor's truck has non stock push-in fittings, not barbed fittings. is it worth trying to make them work or is it safer to go back to barbs?
Old August 18th, 2014, 05:52 PM
byrnecc's Avatar
byrnecc
Conor
1986 ex-mod 110
Ha, news to me. Thanks Ed
Old August 18th, 2014, 05:57 PM
Personally, I think the barbed fitting are a poor design. The best is proper compression fittings with inserts. Push to connect fittings are better than the barbs and not as good as the compression fittings, IMO.
Anywho, all that matters is that you get the correct OD tubing for the push connect fittings.
Old August 18th, 2014, 06:32 PM
byrnecc's Avatar
byrnecc
Conor
1986 ex-mod 110
Are these connections worth reusing?
Old August 18th, 2014, 07:16 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
I would not reuse them as they are plastic line in a metal fitting with a brass or plastic crush olive.
If you need some metal barbs, I have drawers full of them.
Just need to know if your fitting size is 14mm or 1/2 inch (you'll have to figure that out).
If you are routing fuel lines, I would also install a sedimenter and a 12V Fuel pump as well.
That way your fuel system is self bleeding.
RDavisinVA
Old August 18th, 2014, 08:20 PM
byrnecc's Avatar
byrnecc
Conor
1986 ex-mod 110
It took a 1/2" wrench to get them off so I'm assuming that would qualify them as a 1/2" fitting. If I am buying this tubing http://www.mcmaster.com/#5140k94/=tc8kmk should I get these fittings?
Really don't want to order the wrong parts, at $13 those aren't really cheap
Old August 18th, 2014, 08:26 PM
Link does not work for me. Not sure what fittings you are planning on but nothing should be more than a dollar or two.
Old August 18th, 2014, 09:09 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
It took a 1/2" wrench to get them off so I'm assuming that would qualify them as a 1/2" fitting. If I am buying this tubing http://www.mcmaster.com/#5140k94/=tc8kmk should I get these fittings? Really don't want to order the wrong parts, at $13 those aren't really cheap
If you do NOT plan to use bio-fuels, I would use metal barbed fittings to fit your filter and fuel pump and run 5/16" fuel line from the local auto supply with hose clamps.
There are many ways to successfully run new fuel lines and various opinions will come from different people.
I am no fan of the plastic fuel lines for obvious reasons and would never use it.
1/2" wrench has nothing to do with the fuel fitting size.
It's the outside diameter of the fuel fitting.
Get yourself a thread and bolt size key from Fastenal.
They can explain how to use it.
You'll have to unscrew the fitting to measure the size and thread pitch.
John:
I sometimes have to hi-lite links and cut and past them in a new browser session to get them to work.
Give it a try and let us know if it works.
The link Conor posted went to a plastic line.
RDavisinVA
Old August 18th, 2014, 09:49 PM
byrnecc's Avatar
byrnecc
Conor
1986 ex-mod 110
I'm thinking of just getting whole new housing since the current one is very loose and the filter is a huge pain to change (bolt running from top to bottom of filter)...I'd also know what size the threads would be for new fittings. Good idea or no?
Old August 18th, 2014, 09:54 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Sure a spin-on is 10 times easier to change.
You just need enough room to slip the element under the housing and screw it in evenly.
RDavisinVA
Old August 18th, 2014, 09:58 PM
byrnecc's Avatar
byrnecc
Conor
1986 ex-mod 110
Any links? Having trouble finding one...
Old August 18th, 2014, 10:01 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
PM me your email.
RDavisinVA
Old August 18th, 2014, 10:02 PM
sorry for being out of action.
I did some research and it looks like the filter housing is a Lucas / CAV filter:
http://www.autoelectricaldieselfueli...AT_Filters.pdf
Based on the info, the threaded fittings seem to be either 1/2"-20 or m14x1.5mm. If you have any numbers on the filter housing, you can cross reference using the table in the PDF file above. If OEM, my guess is HDF296.
IIRC, the filter housing was fine, no need to replace. The issue was that the rivets holding the bracket for the filter housing were loose in the bulkhead. The filter housing should be affixed to the bulkhead via screws, but I don't know if your bulkhead is tapped for the appropriate screws. At the moment, the loose fuel filter IMHO is not an issue. No need to replace the whole thing, you just need new hose - perhaps fittings - not sure.
That tubing in the link you posted looks too hard to me. probably meant for vacuum service.
Old August 18th, 2014, 10:13 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Excellent link and all around advice Ed...
Seems like those riv-nuts work for a while and then give up over time even when installed properly, especially when over tightened... use to use them for the filters, but gave up a few years ago...
RDavisinVA
Old August 18th, 2014, 10:34 PM
If looking for an alternative, I would suggest the Standadyne FM-100. Fits right in the stock location.
Here is an example of where to find the heads, shown with three different styles of ports: http://www.thedieselstore.com/templa...0Filter%20Head
And the filter elements: http://www.thedieselstore.com/templa...Fm100%20Filter I use a 6", 2 micron element.
IMO, the nylon tubing is a better choice than fuel hose. It is chemically impervious to all fuels including biodiesel. It is cheap and easy to find. With compression fittings, it is rated for 1000s of psi. I'm not sure why people replace it with fuel hose. Good fuel hose is expensive and normal fuel hose will break down over time.
diesel, fuel
Front brake line - why hard line & flex line? jefhuf Defender Technical Discussions 5 January 13th, 2012 09:03 AM
What diameter is the plastic fuel line on a LR diesel evilfij Defender Technical Discussions 17 June 27th, 2010 11:23 PM
200tdi fuel line, hose size tomaco1 Defender Technical Discussions 5 March 12th, 2009 10:38 AM
fuel pump line size? (AN spec) rgrrvr Defender Technical Discussions 0 July 2nd, 2008 02:14 PM
Line Lock for Winch Line Maine 110 The Vendors Loft 6 February 7th, 2006 06:47 AM
» Defender Registry
Blanca
roverguy2
White
KGH
Add your Defender
