2.5 Diesel - Loud Metallic Chriping at Low RPMS - Defender Source
Old October 29th, 2015, 12:00 PM
Sam1
Jl
Proud owner of a newly acquires 110 Tith Soft top. All stock. Hearing a very disturbing loud metallic chirping at low RPMS. Worst at cold start, subsides at higher RPMS most of the time, will go away when engine is warmed up, but will also come back one in awhile when fully warmed up. In gear, out of gear, clutch depressed or not. Sounds like it's coming from the engine. Fearing the worst but want to rule out other potential issues.
Any input appreciated.
Old October 29th, 2015, 12:47 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
You might buy an automotive stethoscope and poke around until you can narrow down where the noise is most likely coming from. Unfortunately there is as many things it could be as there are opinions of what it can be. You might search the UK forums as well to see if anyone has the same description. Mine was the opposite, find when cold then tapping/popping after things warmed up.
Old October 29th, 2015, 12:56 PM
Impossible to diagnose over the internet. My first stop would be to pull the valve cover (5 minutes) and check the valve lash.
Old October 29th, 2015, 01:22 PM
Sam1
Jl
Thanks for the input. I may need to get a stethoscope and poke around some more.
Will pull the valve cover this weekend as well.
Old October 29th, 2015, 01:37 PM
1of40's Avatar
1of40
1of40
Originally Posted by Sam1 View Post
Thanks for the input. I may need to get a stethoscope and poke around some more. Will pull the valve cover this weekend as well.
Might pick up a $15 feeler gauge set as well and check the valve clearances. The process is simple and something you want to figure out anyway as a proud NA owner.
Old October 29th, 2015, 01:48 PM
If you have a cell phone, you can post audio and/or video.
Old October 29th, 2015, 01:58 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Exactly.
It could be anything.
Worked on a 110 once with similar sounds that were caused by the belhousing bolts coming loose inside, then getting jammed near the flywheel that scraped them and made a loud chirping.
RDavisinVA
Old October 29th, 2015, 02:27 PM
loose belt would be most common and most likely ... even properly adjusted belts can chirp if worn. Spraying water on a squeaking belt will take the noise away until it dries out ... for testing purposes!
Old October 29th, 2015, 02:37 PM
Sam1
Jl
Will snag a video of the sound this weekend... all helpful information as well to start digging.
Old October 29th, 2015, 02:48 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Water pump? Mine sounded pretty rattly/screechy when it went
Old October 29th, 2015, 03:09 PM
I like that suggestion. Mine made erratic screeches until it finally seized...
Old October 29th, 2015, 03:26 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
I would say go ahead and pull that worthless turd of a motor out and replace it with a 200Tdi drive train (and throw in power steering while you are at it ) The sound will go away and you will be a much much much happier person.
Old October 31st, 2015, 06:49 AM
tijnes
Martijn
110
Just one more suggestion. My ex mod 110 had worn out fan cowl bushings, one of them broke off and at a certain rpm the fan would rattle against the housing. Very unnerving sound coming from an engine but ended up easy fix
Old November 9th, 2015, 09:53 AM
Sam1
Jl
Was the belt... simple fix. Thanks for all the input!
diesel
RPMs die, then vehicle stalls at next light. sro Defender Technical Discussions 19 November 22nd, 2012 09:23 PM
Knocking when low RPMs but Accelerator depressed near floor rijosho Defender Technical Discussions 6 August 1st, 2011 03:32 PM
Engine loses power at 2500 rpms Hazard Defender Technical Discussions 17 October 15th, 2010 04:57 PM
Engine sweet spot and highway RPMs cgalpin Defender Technical Discussions 32 December 30th, 2009 12:02 PM
misfires at low rpms sometimes jdb3760 Defender Technical Discussions 1 December 3rd, 2006 09:50 AM
