2.25L and 200Tdi engine mounts question - Defender Source
Old April 8th, 2009, 10:59 AM
Gkase's Avatar
Gkase
George Kase
1983 110 200Tdi CSW LHD
I am acquiring a 1983 110 that currently has a 2.25L petrol engine and LT77 trans in it...does anyone know
if a 200Tdi engine would be a drop in fit on the existing chassis engine mounts or do they need to be moved/welded into new positions?
thanks
George
Old April 8th, 2009, 11:02 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
http://www.nicksjungle.co.uk/200%20T...onversion.html
Should have all of the information you need
Old April 8th, 2009, 11:07 AM
Gkase's Avatar
Gkase
George Kase
Dave,
thanks for that but it says:
The 200 Tdi mounts are the same as the original 2.5 variant of ones. The actual engine mounts are the same as the 2.5 TD. Mounting rubbers for engine 200 Tdi are ANR1808...
but the question then becomes, are the 2.5L and the 2.25L mounts the same?
Old April 8th, 2009, 06:38 PM
moose's Avatar
moose
Brett
Ex-Mod Tdi 110 Hard Top
The 200Tdi and 2.5 engine mounts are the same. The 2.25 mount on the right hand side is different, the left hand mount is the same. I am going to replace the 2.25 petrol engine in my Series 3 with a 2.5 NA diesel, and this is the info I have been given from several different sources.
Brett
Ex-Mod 110 Tdi
Series 3 88 Diesel Soft Top
Old April 8th, 2009, 08:58 PM
Brett
I know the above is correct, but I am not sure if the later 2.25 mounts as on a defender were the same as the early 2.25 mounts which is why I did not say anything in the first place.
Old April 8th, 2009, 11:22 PM
2.25 mounts on the defender chassis are not the same as 2.25 mounts on the series frame. the 200tdi should drop right onto the 2.25 chassis, as some members here have done.
Old April 9th, 2009, 02:42 PM
Yup. been there done that, got the Tshirt to prove it.
Old April 9th, 2009, 02:49 PM
Gkase's Avatar
Gkase
George Kase
just to be clear for future thread searchers...the 200Tdi will drop onto and bolt right up to the early 110 frame that had 2.25L petrol motor mounts...no cutting or welding required
Old April 10th, 2009, 08:53 PM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
....and to add to the clarification....the DEFENDER 200 mounts are the same as the early 110. Those trying to bolt a Disco version will disapointed as these engine mounts are very much different .
....or at least the ones I've seen have been.
Matt Browne
200tdi, engine, mount, tdi
200tdi Build Question regarding bulkhead fitting Turbofan Defender Technical Discussions 12 October 21st, 2009 01:59 PM
Is it ok to mount a 200tdi to an engine stand? dave_lucas Defender Technical Discussions 15 July 6th, 2009 12:34 PM
200tdi with no engine numbers tomaco1 Defender Technical Discussions 10 August 4th, 2008 05:13 PM
200tdi retrofit, what to check/service on the engine before fitting? headdamage Defender Technical Discussions 4 March 3rd, 2008 12:51 AM
