2.25 Valve Adjustment - Defender Source
Old June 20th, 2011, 10:16 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Hi all.
So I had my head rebuilt a little bit ago and now I think it is time to adjust the valves after some break-in. I have never done anything like this before so any tips would be greatly appreciated.
All I could find in my manual was how to take the whole engine apart, and I'm not ready to do that now!
Preliminary research shows that .010 might be the right clearance for 2.25 diesel? As far as making any of that happen, I have no idea.
As always, thank you so much in advance
Jeff
Old June 21st, 2011, 12:36 PM
LRover's Avatar
LRover
J. Michael McCaig
It should be the same as a Series 2.25 petrol and that would be .010in for all valves. You do them in sequence as follows: set no. 1 tappet with no. 8 valve fully open, set 3 with 6 open, set 5 with 4 open, set 2 with 7 open, set 8 with 1 open, set 6 with 3 open, set 4 with 5 open, set 7 with 2 open. I always rotate the engine a couple of times and then recheck. You can do it with the engine cold or warm.
Old June 21st, 2011, 10:25 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Ok. Thanks.
So #1 would be towards the front of the engine I assume?
Do you turn the engine over with a wrench then to get the valves to the proper open position?
I know, newbie questions... But I'm trying to learn
Of course, now that you have taken the time to spell that out so clearly I see the description in the literature that I have along with a diagram. Thanks again
Old August 7th, 2011, 01:37 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
So I'm finally getting around to doing this job. Everything under the rocker cover is completely covered in oil. Is this normal? I replaced the o-ring on the breather cap a while back but it is still leaking out of the top now. Just wondering if there is too much oil in here. Thanks!
Jeff
Old August 7th, 2011, 02:08 PM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
Just worry if there's no oil there.
Old August 7th, 2011, 02:29 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Right. As I was doing it I realized that there should probably be plenty there. Thanks. I think I got it wrapped up already.
Newbie valve adjustment question michael67 Defender Technical Discussions 0 November 10th, 2010 12:47 AM
2.25 Land ROver Diesel bstraw For Sale - Parts 2 February 21st, 2006 12:11 PM
air meter voltage adjustment? Rod Hayward Defender Technical Discussions 4 July 24th, 2005 11:24 PM
Fuel line valve cracking RickM Defender Technical Discussions 2 October 21st, 2004 11:15 PM
