2.25 Timing - Defender Source
Old June 29th, 2013, 02:32 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
2.25 Timing
I have had a heck of a time getting this thing timed right. It's the 5 main bearing 2.25 diesel. I had my leaky injection pump rebuilt and when I got that back I tried and failed to get it back on correctly. Then I moved and didn't really have a good place for the truck so I took it to my local shop. After they had it for three months without doing any work on it I figured that I needed to give it another shot so I got it back this week.
I followed the procedure and used the timing tool to set the indicator then placed the pump at that location. It hardly had any power and smoked a lot. Then I started rotating it around to try to find a spot where it had reasonable power and less smoke. After many attempts I got it to a place where it was smoking less but still lacked power compared to before I took the pump off in the first place. Today I fiddled with it some more by rotating in small increments on either side of the previous position and I am still getting lots of smoke under acceleration and power doesn't feel right.
I haven't driven the truck since December except to and from the shop that didn't even touch it in three months. It's getting ridiculous. My rover luck has not been with me this year.
This might just be a rant but hopefully someone has some tips on how to help.
Jeff
Old June 29th, 2013, 07:52 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Jeff:
Do you have all the air out of the fuel system?
RDavisinVA
Old June 29th, 2013, 08:17 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Not 100% sure Robert. Someone told me at one point that these self bleed the air out. True or false?
Old June 29th, 2013, 08:27 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
False...
For the most part, false.
I guess it is possible to force all the air through the injectors, but it would take forever.
Again, get yourself a 12V electric fuel pump and mount it between the tank and the lift pump.
Then crack each injector while the engine is running to bleed the air out of each line.
Repeat until the engine has more power.
RDavisinVA
Old June 29th, 2013, 08:47 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Forever, like driving it 12 miles to the shop? Or forever like I want this engine to go away forever and get a tdi in there?
I will mess with it tomorrow morning and report back.
Will air effect smoke or just power?
Old June 30th, 2013, 02:50 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Still no good. Bled and bled but couldn't get all the air out. I'll try to get a 12v pump to hook up and see if there is a leak somewhere. I might need a new lift pump? It has started to leak a little fuel but not much. Perhaps it is letting air into the system.
Cams, lifters, timing chains vesparover For Sale - Parts 11 March 10th, 2006 11:20 PM
2.25 Land ROver Diesel bstraw For Sale - Parts 2 February 21st, 2006 12:11 PM
Timing and Overheating mkerr2112 Defender Technical Discussions 10 July 6th, 2005 09:31 AM
Why didn't anybody warn me timing chains are so annoying? Hans Misc. Chit-Chat 4 January 16th, 2005 11:40 PM
