1st upgrade: lockers or underdrive - Defender Source
View Poll Results: Best 1st upgrade : Underdrive or Lockers?
Underdrive 2 6.45%
Lockers 29 93.55%
Voters: 31. You may not vote on this poll
Old March 22nd, 2011, 02:51 AM
sad_story's Avatar
sad_story
andre
95' D90
looking to make my 1st significant upgrade to my 5speed 95 D90. Trying to understand/figure out where i would benefit most and why, and therefore upgrade first; Underdrive or F/R Lockers (if you are in the locker camp, front and rear or only rear)?
the floor is yours ...
Old March 22nd, 2011, 03:30 AM
TS888's Avatar
TS888
Tony Sims
1984 110
For reference, what is your experience level in off road driving? If you are relatively new to off roading, then the best thing to invest in first is training, like a Bill Burke class. A Land Rover is a very capable truck straight out of the box, and learning to use all that capability will help you decide what changes you may want to make.
That said, have you got some form of winch, and a full set of recovery gear (tree strap, snatch block, shackles, etc.)? A hand winch is a good investment for occasional off roading (Tirfor or More Power Puller), and useful even if you decide to go for a truck mounted winch later. Before you invest in gear that can get you further from pavement, you should be prepared to get back, and be experienced in self-recovery.
If you are experienced, please don't be offended by my prior suggestions. Then I'd say lockers before underdrive. The greater torque of the underdrive with open axles will mean a lot of spinning wheels. As lockers go, rear first, then front if you aren't doing both in one go.
Tony
1984 110 "Smokey" (sold)
Old March 22nd, 2011, 03:42 AM
Neither would be anywhere near a first upgrade.
This is sort of in the class "if you have to ask, you don't need them".
Old March 22nd, 2011, 04:04 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
I'd vote for some dcent tyres and axle protection.
Old March 22nd, 2011, 07:53 AM
Cred's Avatar
Cred
Clarence
1994 D90 #1057
Tires are great way to start. Also skid plates, upgraded axle shafts, cvs, and drag links. I'd do those items way before lockers or an underdrive.
Old March 22nd, 2011, 07:57 AM
EWR's Avatar
EWR
Carey
1954 CJ-3B
This is very sound advice. One of the best upgrades is seat time. I have watched first hand guys that have thrown large amounts of cash into lockers, gears and amazing suspensions only to be made to look like a complete idiot as they get hung up on an obstacle that a skilled driver in a stock truck walked right through.
It's 95% driver input.
What tree?
Old March 22nd, 2011, 12:01 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
Buy it all...lockers,tires,gears,protection,winch,bumpers ! Then go buy some booze and a couple pairs of undy's and learn to drive it! Wheel it like it's your kid's car.
Old March 22nd, 2011, 12:21 PM
Winch is cheaper, easier to install and will also get you out of trouble.
Old March 22nd, 2011, 01:55 PM
EWR's Avatar
EWR
Carey
1954 CJ-3B
Or, just a buy a stock Rubicon edition Jeep Wrangler and you'll be set, and have great aftermarket support, a reliable vehicle and about 15k less into it.
What tree?
Old March 22nd, 2011, 03:33 PM
Man, when I saw you replied in here I was fully expecting to see you suggest a Ford or Chevy block over the stock engine as the first upgrade.
Old March 22nd, 2011, 04:18 PM
Cube II's Avatar
Cube II
Michele
1997 D90
At the beginning I thought this poll was a joke...
I'd ask "how long have you been driving your D90?"
Lockers and underdrive have different purposes, hence my
Lockers.
Assuming, of course, you already have mud tires, a winch, and other upgrades as suggested by other fellow forumeers...
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
Old March 22nd, 2011, 07:11 PM
What he said
------ Follow up post added March 22nd, 2011 07:12 PM ------
Troll
Old March 22nd, 2011, 08:47 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Winch. Lockers and tires will let you get more stuck, just like 4WD does.
Then tires.
Or tires then winch.
Why are you considering an underdrive?
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old March 22nd, 2011, 09:22 PM
I too, want an under-drive... They are spectacular and I will have one on my 100".
Old March 22nd, 2011, 10:19 PM
cdb
Clark Bowen
I have both lockers and an underdrive on my D90.
Frankly, I avoid using my lockers as much as possible to improve my driving skills. I used to put them in any time I came to an obstacle and it did make it easier but you don't "need them". Learn without them first.
I also have the Ashcroft Underdrive and especially for hard surfaces (rockcrawling) I really just use it for coming down steep slopes or ledges -- very, very slowly.
I've found that with the Underdrive in, and in low range I'm using 3rd gear to climb. That's virtually the same as low box, first and no Underdrive. So why bother paying the money for the underdrive and installing the 26 tooth t-case gearset or finding a 1:4 t-case.
While I'm at it - don't retrofit an a/c system if you don't have one already. Near useless in a soft top.
I think the above advice is excellent - even the Rubicon. My son has one after getting frustrated with Range Rovers. Quality is so so and you need aftermarket suspension components but at least the damn a/c works.
------ Follow up post added March 22nd, 2011 07:31 PM ------
Just noticed that you live in Seattle.
Join the Pacific Coast Rover Club www.pcrc.net to meet fellow rover nuts. They are very active in Seattle and Portland and a good group to boot.
Also, I cannot see any advantage to an underdrive where you live unless you are going to drive to the SouthWest for rocks.
A good set of mud terrains would be my first order of business, followed by a winch - you have lots of trees to strap onto. Oh yes, get a tree strap and some 3/4" D rings (clevis) from a logging store. Cheaper usually.
Of course, you have to buy a winch bumper for the winch. Doug Shipman may have some left: 503-252-5566 or Rockware www.rockware.net.
Checkout Lamorna Garage (Gord'n Parrot) and Briggs Automotive for local Land Rover shops.
2011 RR HSE -
2001 GMC 2500 4wd
Old March 23rd, 2011, 02:06 AM
sad_story's Avatar
sad_story
andre
95' D90
Should have made it clearer what i already had, i guess i should have clarified. But thank you allThanks so far for the responses
this is how i bought this rig from Keith @ Copley (thanks K) and what the prior owner had done with it @ ECR
Work @ ECR link
- Anodized Chasis
- SS line/brake/fuel
- SS Rox Exhaust
- ECR 4.6L, ECU/Performance Manifolds
- Bilstein Shocks
- ROX Tie Rods guard / HD drag link
- F/R Diff Guards
- Rox Fuel Tank Skid Plate
- block heater and A/C
- Tuffy Center Console
- Drivers ROX kick Panel
- Door hinge upgrades
- heated seats
- LED tail lights
- SG front bumper w
- Warn Winch
- Hella 4000s
- Badger Seat covers
- ROX seat rails
@ TS88
Bill Burke Class - Done (awesome two days (thanks B.Burke and attendees)
@ TS88
Full Recovery Gear - Check (thanks Thor @ Vicking)
@ TS88
Hand Winch - Check using the Hi-Lift ala bill burke
Rock Sliders - Check (Matt @ Rockware)
Quick Disconnects - Check(thanks Gord'n @ Lamorna)
@ TS88 (Tony), diesel_jim, Cred, EWR Carey, 02batsea Bill), JSBriggs(Jeff)
pretty much already came with the things mentioned
@cdb
thanks for the insights,yes already joined pcrc last week (i just moved to the area)
Thank you all very much for the information and advice ... Yes I am a relative novice, just moved to a city where owning a D90 is worth it. I think i bought one that seems pretty loaded with the basic and then some (though with gas prices i sometimes wonder about the TDi conversion... yes i understand and appreciate the advice about learning to drive what i have before i upgrade, point taken. I get out to the woods about every two weeks to practice and learn, and have tried to augment that by attending Bill Burkes class and hopefully get out with the local meetup.com groups as well as the PCRC guys.
In conjunction with your answers and BBurkes advice, the next step will be rear lockers before front lockers before (if at all) underdrive. As for timing, plans are to get a lot more driving in this summer fall, then come winter see if my skills and area require me to move on... its just i wanted to know what my upgrade path should be and what i should keep an eye out in case there are any "deals" to be found or keep a look out for...
Old March 23rd, 2011, 09:42 AM
EWR's Avatar
EWR
Carey
1954 CJ-3B
Is this a coniston green SW by any chance?
What tree?
Old March 23rd, 2011, 09:53 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Forget the idea of a tdi conversion, just put it out of your mind. You already have a sweet upgraded motor and a diesel conversion NEVER pays itself off in mileage savings.
Old March 23rd, 2011, 07:18 PM
sad_story's Avatar
sad_story
andre
95' D90
arles blue will post photos when i get home
------ Follow up post added March 23rd, 2011 04:20 PM ------
I have been hearing that a lot ... but so limited on 150-170 range :-( ...
Old March 23rd, 2011, 07:29 PM
cwilder's Avatar
cwilder
Chad
2012 110 Black
Very nice truck! Congrats!
'97 D90 SW LE - Supercharged & Lockers Classic Rover For Sale - Vehicles 18 February 26th, 2006 12:32 PM
Suspension upgrade Rover- Girl Misc. Chit-Chat 41 September 12th, 2005 02:07 PM
OME upgrade advice kolvedic Defender Technical Discussions 11 August 16th, 2005 11:08 PM
Turbo/Supercharger upgrade advise needed babushka99 Defender Technical Discussions 2 October 16th, 2004 08:26 PM
Upgrade pushed back chrisvonc Misc. Chit-Chat 0 May 15th, 2004 11:23 AM
