1st really cold weather questions - Defender Source
Old December 20th, 2004, 08:06 AM
mspell
Michael Spellman
When starting up the truck, the oil lamp stayed on for about 5secs. Is this a normal condition caused by the 10degree F temp outside?
Also, has anyone replace the bearing on the most forward pulley attached to the crankshaft(I think it drives the water pump)? Mine is starting to rattle a bit.
Old December 20th, 2004, 08:32 AM
Yep, it is something kinda common to Rovers when they are real cold. What weight oil are you running?
Are you talking about the tensioner pulley or the pulley right on the water pump? If the tensioner we did talk about replacing the bearing and I was going to try, but in the end I just replaced it, then I was going to rebuild the old as a spear, but now I am putting the 4.0 in I won't need it. If it is the water pump then you need to replace the hole pump.
Old December 20th, 2004, 11:56 AM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
and you just happen to have one or two spare Mike
Old December 20th, 2004, 12:35 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Man, the cold comes out and so do the odd problems.
Blew the fuse for my wipers last night on the way home from work..... and of course I don't have ANY 15amp spares right now.
But that's ok, because when the doors get all icy on my Station Wagon, the button gets stuck IN so the door won't latch shut again.
-Hans
My oil line fix
My 100k stopped odometer fix
Old December 20th, 2004, 12:45 PM
mspell
Michael Spellman
The pulley I'm referring to is the one off of the crank that drives *I think* either the fan or the water pump. It's about 6" in diameter. Looking at the motor, it's at 6:00 o'clock, whereas the water pump is at 11:00 & the tensioner at 9:00.
Old December 20th, 2004, 12:57 PM
um you are describing the pulley on the end of the crank shaft, there is a bit of work involved in replacing that. I bet it is the tensioner pulley or water pump. Loosen the belt up and spin the pulleys by hand to find the problem.
Old December 20th, 2004, 08:40 PM
mspell
Michael Spellman
Nope, I'm the guy who posted the step by step on how to rebuild the tensioner pulley a few mos ago, & I also just replaced my water pump in August, so I know it's not either of those. I've identified it as the one off the crankshaft, so if anyone knows how to R&R I'm all ears.
surprised at 300Tdi cold weather starts Gkase Misc. Chit-Chat 6 December 6th, 2006 09:11 AM
Problems shifting out of 1st when cold chalkcreek Defender Technical Discussions 2 July 14th, 2006 10:56 PM
Cold Weather Starter Problems boshea Defender Technical Discussions 9 October 25th, 2005 04:35 PM
Excessive Cold Weather Exhaust boshea Defender Technical Discussions 3 January 9th, 2005 02:44 PM
? for you cold weather people javelinadave Defender Technical Discussions 8 November 24th, 2004 12:34 PM
