19J TD air filter??? - Defender Source
Old March 10th, 2016, 12:26 PM
awdbandito
JD
'68 2A
Is there a domestic part I can buy at my local auto parts store for the air filter in a 19J turbo diesel?
Old March 10th, 2016, 02:38 PM
Parrie's Avatar
Parrie
Parrie Willette
1989 D90 P/U
I just replaced my filter and also tried to find a replacement locally with no luck. The filter really isn't anything special so I assume there would be an equal out there but I could not find anyone that could cross the numbers. Ended up getting mine from Trevor at Rovafarm.
Old March 10th, 2016, 02:56 PM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
See if you can get any of these stateside.
LX 730,MAHLE FILTER LX 730; Air Filter
Old March 10th, 2016, 03:05 PM
It crosses to a common industrial filter. I forget the numbers now, but if you take one to an industrial supplier they will be able to match it, CAT, Case, etc..... Used in a lot of smaller machines like CASE skidsteer loaders.
Old March 10th, 2016, 03:16 PM
Parrie's Avatar
Parrie
Parrie Willette
1989 D90 P/U
Hey Guys, thanks for the info. I did a google search and wasn't able to find anyone that carries the Mahle brand but I did find a list of cross reference numbers...there are several FRAM and Bocsh filters that should work. Red90...I do believe that you are correct that it is a common industrial filter...the filter bares a striking resemblance to my old Miller D50 diesel welding machine.
Old March 10th, 2016, 03:19 PM
JohnsD90's Avatar
JohnsD90
Of the ones I quickly crossed through wix and fram I didn't find this. But it looks like a common sized filter.
I know my Perentie air filters is a Donaldson AU part that Donaldson US doesn't recognized, I crossed the AU number to wix or fleetgaurd and then crossed that number back to Donaldson US and got a match (different part number, same dimensions). Funny when I pulled the old filters one was made in the USA, and they were identical to the USA part (filter color and weave), I'm sure it has to do with contracts and that fun stuff.
Old March 10th, 2016, 03:24 PM
I used to buy the filters at one of the local industrial parts places. It is quite common. The CASE loader we used to have at work used the exact same one. As long as the parts guy at the counter is not a child you should not have a problem....
Old March 10th, 2016, 04:29 PM
awdbandito
JD
'68 2A
Thanks all. I'll call around and see what I can find.
19J Oil Filter The Dro Defender Technical Discussions 7 July 22nd, 2015 09:01 AM
19J Fuel filter head bleed bolt IvanKV Defender Technical Discussions 0 November 22nd, 2014 01:44 PM
200tdi air filter element and air box bossman429 For Sale - Parts 2 February 23rd, 2013 07:08 AM
2.5 Td - Oil Filter and Fuel Filter gonzanc Defender Technical Discussions 5 November 3rd, 2012 01:38 PM
TDI sediment filter - OEM is Delphi CAV filter? jaherring Defender Technical Discussions 2 October 25th, 2010 03:33 PM
