19J pressure buildup - Page 2 - Defender Source
Old July 14th, 2014, 06:35 AM
grapplerdan's Avatar
grapplerdan
Dan
1989 110 CSW 200TDi--now with 19J
Thanks for the input. I'll check the injector pump, as that was my initial thought.
Unfortunately, I can't get it back to the UK to have them fix it, as I am stuck in Germany waiting for orders to move a the end of the month. I will try taking the original head to a machine shop to have it machined, new hotspots put in.
Hopefully, adjusting the injector pump will clear it up.
Dan
Exercise ferments the humors, casts them into their proper channels, throws off redundancies, and helps nature..., without it, the body cannot subsist in its vigor, nor the soul act with cheerfulness.
Joseph Addison (1672 - 1719)
Old July 14th, 2014, 08:36 AM
Dan
I wouldn't bother doing anything/waste any more money with that old head other than melt it down for use as a boat anchor.
When I said timing I meant the crank, cam, and injection pump aren't in time, ie something was allowed to move while you had it apart. The fact that its off so far its making a strange sound isn't good.
Pretty sure you are off by two or more teeth with your timing belt, what you describe is unburnt fuel, the fact that it will only run @ higher rpm again is because the injectors are firing either too early or too late. Lock the crank, lock the injection pump and see if the cam gear lines up. I'll bet one or more is off by a couple of teeth.
Old July 18th, 2014, 10:39 AM
grapplerdan
Dan
Woohoo!!! After much praying and begging advice, I lucked out. I only had to reset the valve clearance, then burped the fuel line and made sure injector #1 was set. Then she started up, minimal smoke. Took her for a test drive and all is well: no overheating, no pressure build up, nothing.
Just got my orders and have 2-weeks to clear. Going to clean her out and ship her. Hopefully, the govt will pay for it, but I have heard nightmares from everyone regarding the new shipping contractor the military is using. She may be too rusty for them and I may have to ship her out of pocket.
Thanks for everyone's help and support.
Dan
M416 buildup javelinadave Smaller Projects 7 October 5th, 2014 02:03 PM
Wanted : 19j parts Whidbey Wanted 1 August 15th, 2012 02:21 AM
19j exhaust and intake millerhlyf Wanted 1 March 23rd, 2011 10:06 PM
Thoughts on a 2.5TD 19J tomaco1 Misc. Chit-Chat 1 December 5th, 2010 08:47 PM
Diesel turbo 19J engine parts CDNRover For Sale - Parts 6 August 7th, 2009 11:08 AM
