19J Oil Pressure Sender Connection - Defender Source
Old May 18th, 2015, 05:27 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
Anyone find a good way to add a oil pressure switch to the existing location on a 19J...the sending unit is pretty fat and does not fit between the oil filter...before I try and look for some parts at home depot I thought I would ask...prob need a few inches to clear or a 90deg bend...
America Runs on Dunkin'
Rovers Run on Diesel
2017 Range Rover L405 HSE TD6
2008 Range Rover HSE L322/MkIII - Gone but not forgotten
1988 D90 County RHD 2.5TD
2015 Porsche Cayenne TD
Oil Leaks and Pressure build up on 19J 2.5TD Engine richord Defender Technical Discussions 9 August 13th, 2014 06:16 PM
Tdi VDO oil pressure sender help Uncle Douglas Defender Technical Discussions 15 August 1st, 2014 12:08 PM
Has any one installed a VDO oil pressure sender on the '97 - 4.0? LenB Defender Technical Discussions 8 March 29th, 2010 01:30 PM
oil pressure sender tomaco1 Defender Technical Discussions 2 October 7th, 2009 09:00 AM
Part # for Oil Pressure Sender 61rover Defender Technical Discussions 2 June 8th, 2009 05:29 PM
