19J Oil Filter - Defender Source
Old July 16th, 2015, 12:47 PM
The Dro
Dro
1988 Ninety
19J Oil Filter
Anyone know what type of oil filter it uses?
Old July 16th, 2015, 01:08 PM
ontheway's Avatar
ontheway
Dave
1986 RHD 110 SW OM617
Probably like this, from a 2.5 NA
1986 Land Rover 110 SW
1995 Land Rover Disco (Sold)
Old July 16th, 2015, 01:16 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Same as most all the other engines, ERR3340
Old July 16th, 2015, 01:22 PM
The Dro
Dro
1988 Ninety
Thanks guys
Old July 16th, 2015, 01:23 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
ROVER ERR3340 - Alternative oil filters
~ Semper Fidelis ~
Old July 16th, 2015, 01:37 PM
You can use a PH8A equivalent. It is a longer filter, but fits fine. It is probably the most common filter size around.
Old July 16th, 2015, 11:29 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Wix 51515, Napa Gold 1515 or Baldwin B2.
I wouldn't use OEM (Cooper), they are crap (rubber anti-drainback valve rather than silicone and bypass on the dome end) compared to the above 3.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old July 22nd, 2015, 09:01 AM
lennix's Avatar
lennix
Lennie
1993/Defender Tdi200
I've often used the Toyota 15600-41010 filter on my Tdi 200. This filter is specified for Toyota 3B, 14B, 2H, 12HT and other engines which have a capacity of 3,5 to 4 litre naturally aspired and turbo charged diesel engines. Its a larger capacity filter and fits straight on the the Defender. Ive havent noticed any negative effects on oil at any temperature, so Im assuming this is at least as good as the specified Land Rover part.
19J Oil Pressure Sender Connection icnsltmfg Defender Technical Discussions 0 May 18th, 2015 05:27 PM
2.5td (19j) oil filler cap to valve cover icnsltmfg Defender Technical Discussions 0 April 18th, 2015 02:05 PM
19J Fuel filter head bleed bolt IvanKV Defender Technical Discussions 0 November 22nd, 2014 01:44 PM
Oil Leaks and Pressure build up on 19J 2.5TD Engine richord Defender Technical Discussions 9 August 13th, 2014 06:16 PM
2.5 Td - Oil Filter and Fuel Filter gonzanc Defender Technical Discussions 5 November 3rd, 2012 01:38 PM
