19J Fuel Pump Leak - Defender Source
Old February 7th, 2014, 11:04 PM
naw
Nicole
1986 ex-MOD Defender 90
19J Fuel Pump Leak
I am experiencing fuel leaking from my 1986 ex-MOD Defender 90 (19J), seemingly at the fitting between the 4th fuel injector pipe and the fuel pump. Prior to the current issue, I replaced this fuel pump line when the pipe experienced a crack part way down the line. The new line (Brit Part) worked well for two months until it started to slowly drip, seemingly at the fitting into the fuel pump. I then replaced the line with the OEM part from LR Direct. Two weeks later, the drip returned. It gets worse over time, dripping at a higher rate, eventually getting to the point where the 4th cylinder no longer fires due to insufficient fuel pressure/injection. The threads and flange on both the fuel pump and fuel injector line appear clean and in good condition.
Any ideas why this is leaking and what I can do to fix it? I appreciate any help!
The cleaner connection in the photos is the troubled fitting.
Old February 8th, 2014, 08:02 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
I was having what sounds like a similar problem and needed a quick fix. The first thing I thought of was trying plumbers tape. Funny enough it worked and has held for over a year now. Only regret is its a ghetto fix I'm not proud of.
Clay
Old July 5th, 2014, 06:52 PM
xjahx's Avatar
xjahx
JAH
'93 NAS 110, '94 NAS ST, '85 90 PU
Any updates on the success of this solution, plumbers tape?
I have a similar leak at the connection between the body of the injection pump and the take offs of the hard injector lines.
See attachments including video.
fuel
D90 Fuel pump stays on jackaaaps Defender Technical Discussions 0 January 23rd, 2014 09:46 PM
