1997 D-90 Idle Speed - Defender Source
Old October 8th, 2006, 03:39 PM
ndhlp
Matt Mitchell
Question 1997 D-90 Idle Speed
My 97 D-90 Idles at 1,500 to 2,000 RPM. I had a bad O2 sensor and replaced it (by the way, is there any way to reset the check engine light without an OBDII reader?) with no change. I know on previous years there was an idle speed screw you can adjust. Is there anything on the 97s? If so where exactly is the screw, I could not find it. Also, this engine was replace by the previous owner with a 99 Disco 4.0 at 65K (125K on it now). I bought it from a 3rd party and the seller did not know if this problem existed ever since the engine was replaced. I checked for air leaks and found none that were apparent. Anything else I can do?
Old October 8th, 2006, 04:38 PM
jimngo's Avatar
jimngo
Jim Ngo
1994 D90 #80
Try resetting the ECU by disconnecting the battery for 30 seconds or so.
Old October 10th, 2006, 10:31 AM
Chazza
Charles Edwards
1998 V8 50th & 1992 RR LSE 4.2
This sounds like a very similar situation to one that I found myself in last year, it could be an intermittant fault with your throttle position sensor. The link below may be of some help, you will need to find someone with a computer so you can quizz the brain for it's stored settings though...
http://forums.lr4x4.com/index.php?showtopic=1260
Hope this helps
Old October 10th, 2006, 06:03 PM
BarryO
Barry O'Mahony
97 D-90 SW LE
Nope. But cheap readers can now be had, so pull the code and reset it yourself.
Old October 11th, 2006, 11:43 AM
tron's Avatar
tron
Thomas F
Recently Roverless
If you don't want to fork over the $40-$100 to get one, the guys at your local auto store will usually let you use the one they have for free (as long as you don't show up there every weekend).
1997, 90, 97, d-90, idle
Fault Code 48/fast engine idle speed arbik Defender Technical Discussions 9 June 2nd, 2006 07:02 AM
1997 Defender 90 Wagon on Ebay! Willh For Sale - Vehicles 2 July 26th, 2004 05:19 PM
For Sale 1997 Defender 90 djshepard1 For Sale - Vehicles 2 March 28th, 2004 09:12 PM
1997 Defender 90, 18K Miles Landrover For Sale - Vehicles 1 January 20th, 2004 06:34 PM
