1995 D-90 Ecu (amr3947) - Defender Source
Old July 7th, 2006, 09:33 PM
Doc_t7
Keith Fiscella
1995 Defender 90 Hard top
Unhappy 1995 D-90 Ecu (amr3947)
I have a 1995 Defender 90 Hard top (369/500) and the ECU (AMR3947) has failed. Land Rover tells me that that there are no more available. Dose anyone know of anyone that can rebuild the ECU or has one in stock?
Old July 7th, 2006, 09:56 PM
artm
Arthur Maravelis
97 SW
http://www.bba-reman.com/catalogue/R...tion=Landrover
There should be companies repairing these. After all it's simply a little computer - fix the damaged circuitry and reload the eprom.
If all else fails you can do Megasquirt. Lucky bastard!
Old July 8th, 2006, 10:22 AM
Doc_t7
Keith Fiscella
Unhappy
I called BBA-Reman, they do not work on Landrover ECUs anymore, and don't have any in stock. This is the same thing I heard from all the rebuild that I found on the web.
Old July 8th, 2006, 12:44 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
I'm having trouble finding a cross reference for that number, so here are a couple more questions for you. Does your engine have a distributor Distributor? And also, on top of the mass-air sensor does it say 5AM or 20AM? Also, does the ECU have another label that says 14CUX on it? Land Rover had a few various part numbers for various ECU's, most of which are functionally the same.
Click on this link, and let me know which one yours looks like, and we can let you know what to get.
http://www.carelect.demon.co.uk/rrind.html
Here are another couple potential sources, though expensive.
http://acdelcocomputers.com/computer...land-rover.htm
www.carcannibal.com
Just be careful if you buy from E-bay, as I've seen a lot of mislabeled Discovery ABS computers that say they are engine computers. If it's stamped WABCO on it, it's NOT what you want.
-Hans
My oil line fix
My 100k stopped odometer fix
Old July 8th, 2006, 01:37 PM
Andrew Vick
Andrew Vick
95 D90
You may want to try Bill's European in Santa Fe. (505) 471-3399. He may have what you need.
Old July 9th, 2006, 02:03 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
If it is a 14CUX (like my 94 3.9L was) any ECU from a 94 95 disco, or rangie wiht the 3.9L are all the same. I went through this a while back. I just found this one:
http://www.roverlandparts.com/index....OD&ProdID=1455
This is what I found from a pick and pull alst time I needed one. Also try posting on disco web and see if any of the guys over there have a used one they woudl give up. Just a reminder this is only if it is the 14CUX! all the part numbers can be skrewie on rovers, my MAF on the truckl was the same as a 93 rangie... wierd.
Old July 12th, 2006, 11:36 PM
Doc_t7
Keith Fiscella
my mass air says 5am
and the ecu does not say on it if it is a 14cux
but the guy who works on it from landrover says it has to be and that he is positive of it
on the ecu all the other info on it reads as follows:
amr3947r
lrz262
36544801
remanufactured by delfi deisel
thats everything i could find on it
The only company that I have found that will work on it is:
AutoCraft Microsystems, LLC
Engine Control Units Direct Division
233 Tresca Road
Jacksonville, FL 32225
United States of America
1.800.685.1925
I have been talking to Dave at Ex#107
Plus they put a life time warranty on it
Old July 13th, 2006, 08:29 AM
Abrooks's Avatar
Abrooks
Tony Brooks
I've been running an ecu from a 95 disco for about 6 years now -- much easier and cheaper to find than a defender one.
Old July 13th, 2006, 04:09 PM
Roverowner's Avatar
Roverowner
Brian Love
95/Disco
Or...
...Put a HS2.8L in and not have to worry about it at all.....not exactly the cheapest route, but....
Inspirational Thought of the Day
Some people are like Slinkies ...
Not really good for anything, but they still bring a smile to your face when
you push them down a flight of stairs.
1995 Discovery
Old September 18th, 2006, 04:38 PM
jeepguy99
Peter D
I would strongly recommend avoiding ECU Direct (Autocraft Microsystems - ecudirect.com) at all costs. They claimed to remanufacture my faulty '99 WJ ECU for several hundred dollars and I paid to have it reinstalled by a mechanic. Hundreds of dollars of diagnostics later (dealer couldn't find the problem, had to go to an electronics specialist), I find out that they never fixed it. I sent it back for them to repair again and they couldn't even find the problem. Ultimately, they told me that if I spent an extra $100 they'd send me a different one so for $100 more, I finally got one that works. All in all, it cost way more than even full list price at the dealer! When I had their tech support on the phone, they were very deceitful about their testing and remanufacturing practices and even tried to convince me it couldn't be the ECU but was an incompetent mechanic. Needless to say, I won't ever buy from them again. Save yourself the money and headache and get an ECU from the dealer.
Old September 18th, 2006, 04:48 PM
btate
Bryan Tate
d90
John at Tidewater rovers has several 910-763-3335
He uses disco ecu's
Not the cheapest, but he has them
I saw one cheaper on ebay.....
1995, 90, 95, d-90, ecu
F/S 1995 Defender 90 ToddR For Sale - Vehicles 9 September 19th, 2016 06:09 PM
1997 defender 90 - 1995 defender 90 wagon d90boy Wanted 12 January 22nd, 2010 02:36 PM
1995 Defender 90 ST 2468 with 43000 miles EXCELLENT CONDITION funrover For Sale - Vehicles 1 September 25th, 2008 08:52 PM
ECU pinout for 1995 D-90 boxerhips Defender Technical Discussions 8 January 13th, 2006 01:51 PM
1995 defender 90! TwisteD90 For Sale - Vehicles 38 November 4th, 2004 10:15 AM
