1990 Classic - Page 2 - Defender Source
Old February 17th, 2014, 08:09 AM
Time for a YBE upgrade
Old February 17th, 2014, 04:17 PM
Ray_G's Avatar
Ray_G
Ray Gerber
For the sake of giving the OP more input, I reached out to a non-forum dweller who has ~20 RRCs in his stables with the symptoms as described in 1st post:
"Stepper motor back of plenum chamber replace or at least remove and clean.
There is also a vacuum line goes from fuel regulator to plenum I think replace with new but also check if it has fallen off.
Clean intake. Remove air intake and spray throttle plate and make sure all lines going in and out are also clear. Also remove gray breather on right valve cover remove mesh clean and replace.
Fuel pump….
Check and clean ALL electrical contacts to and from coil including grounds"
Old February 17th, 2014, 04:26 PM
ive had some wierd stuff happen very similar to the op, i replaced the o2 sensors and its been a lot happier im using an astro van stepper. ive had the surging under power and it was the tps i was under the impression that the vss in the 14cux didnt play a critical role in operation, ill unplug it and cruise around
now i know why nomar has such low mileage on his hunter
Old February 18th, 2014, 10:23 AM
McQueen's Avatar
McQueen
Peter
'97 D90
Fuel pump….
I will do a check of all you have suggested.
I will get back to you with results. I kind of had the same issue with a D90, and it was the stepper motor that went bad.
Old February 18th, 2014, 10:45 AM
stepper motor issues definitely causes poor idle ... but given that you truck idles fine in N I would suggest that the stepper motor was perfectly capable of maintaining a steady idle.
Old February 18th, 2014, 11:38 AM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
I still say the throttle butterfly is carboned up. We used to get this call all the time in the 90's when RRC's where everywhere. It is a common problem come to a stop and it stumbles or shuts off then restarts easily.
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old February 18th, 2014, 11:39 AM
why would it idle fine in Neutral??
Old February 18th, 2014, 02:55 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
They would do that at times why I haven't a clue. It's a nearly free 5 minute fix to try.
Eric Riston
Old February 18th, 2014, 03:49 PM
In the time it takes to read this thread, you could test every component on the EFI system....
Old February 18th, 2014, 04:28 PM
true ... but you could prioritise the ones that are most likely to be causing a problem ... and stay warm while doing so.
Old March 5th, 2014, 02:38 AM
Why is this entire thread in the Series truck discussion area ? 13 of 30 posts by site team members but no one moved the thread. A classic has the same injection and ignition systems as a 93,94, or 95 Defender but nothing in common with a series truck.
Old March 5th, 2014, 09:16 PM
McQueen's Avatar
McQueen
Peter
'97 D90
Yeah....thats helpful information. Thanks
Old March 5th, 2014, 09:23 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Round headlights?
Old March 7th, 2014, 04:29 PM
Rust
Old March 8th, 2014, 01:24 AM
aka rover's Avatar
aka rover
ed angel
95 D90
10 spline axles
85 D110 3.5 3 DR
Old March 11th, 2014, 02:30 PM
djrover's Avatar
djrover
Dave Johnson
'91 RRC
Did it run fine prior to your tune-up?
If it did, then I would agree on checking the vacuum lines - maybe one got pulled off while the guy was doing the wires/plugs.
I also have had similar problems with a faulty TPS - as suggested by someone else, disconnect it and see if it alters what you are experiencing.
Please post the solution.
_________________________
Dave J.
'91 RR Classic
'01 RR 4.6 HSE - Gone!
'00 Disco 2 - Gone!
'95 Disco 5-Spd - Gone!
'92 RR County SWB - Gone!
'63 2A SWB - Gone!
Old March 11th, 2014, 05:19 PM
robertf
Robert F
1995 Discovery
check the distributor pick up air gap
make sure there isn't too much tension on your throttle cable keeping it open
Old March 11th, 2014, 05:41 PM
Maybe no-one noticed. I just did. Moved
Originally Posted by pendy
I'm here for the D's
Old March 11th, 2014, 06:27 PM
bearskinrug
patrick
lookin
My 90 did this and the culprit was a shitty aftermarket distributor, which was nearly new. Replaced with genuine part, fixed it right away.
Old March 11th, 2014, 07:09 PM
i didn't notice ....
Off road 1990 RRC for sale draaronr For Sale - Vehicles 41 March 6th, 2014 02:01 PM
1990 Range Rover w/37" MTR's and Toy Drivetrain lwg For Sale - Vehicles 0 October 17th, 2005 03:06 PM
1990 RRC Parting Out!!! harrellee For Sale - Vehicles 0 June 6th, 2005 11:04 PM
Two RR Classic 6 CD magazines for stock stereo jack frisch For Sale - Parts 0 February 27th, 2005 02:01 AM
1990 Range Rover County stock/never offroaded jack frisch For Sale - Vehicles 0 February 21st, 2005 06:00 PM
