1983 110 Required Reading (?) - Defender Source
Old July 8th, 2012, 01:17 PM
texrover's Avatar
texrover
Jason
So what are the best manuals/books for a 1983 110 with a 200tdi?
I've got on order:
Land Rover Defender Restoration Manual (Restoration Manuals) - (Haynes)
Land Rover 90 & 110 Owner Manual (Official Handbooks) - Brooklands Books Ltd;
Land Rover 90, 110 and Defender Diesel Service and Repair Manual: 1983 to 2007 (Haynes)
Land Rover 90-110 Defender WSM 1983 (Workshop Manual Land Rover) - Brooklands Books Ltd
Any recommendations?
2003 RR L322
1971 Series IIA
1983 110 SW (Incoming)
1994 D90 ST (PO)
Old July 8th, 2012, 08:01 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
You can get most of the information you need on the web however I like to have a hard copy of the LR Repair manual. You can get one for the Defender with the 200 Tdi. It will go over all the body, suspension, electrical and engine.
Land Rover 110
Old July 2nd, 2015, 05:48 PM
jgrear
Jason
1973 Series III Diesel 2.25
Manual for 2.5 NA MOD
I can't seem to start another thread on this topic, so posting here instead. I've scoured the web, and can't find decent workshop and parts manuals for my 1984 110 with MOD 2.5 NA (Turner head). The available PDFs are missing a lot of material. A simple example is that none of the manuals I've seen cover the throttle linkage, except for the hand throttle. Haven's seen the Haynes or Brookland ones first hand. Are these any better than the widely available 90/110 PDFs?
Old July 2nd, 2015, 06:04 PM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
I have been using the workshop manual...seems to cover just about all you need the know....
Rick
06 L322 Range Rover "The Black Pearl"
06 L322 Range Rover "2.0"
97 Disco SD "Emma" (250k and going strong)
95 P38 "Gus" RIP
99 P38 Callaway Edition #106 RIP
85 Defender 110 2.5NA "Margret"
01 D2 SE7 "Cuzn It" (blown up POS)
03 D2 SE "Fred"
Hoarder of 2.5 NAD parts
"In God we trust. Everyone else keep their fucking hands where they can be seen."
Old July 4th, 2015, 05:22 PM
jgrear
Jason
Stuff not covered in manuals
My posts keep disappearing, but what I'm trying to get across is that NONE of the parts or service manuals I've seen cover the particular thing I am trying to fix right now. In this case, it is the throttle linkage (not the hand throttle), but it's probably not the only missing detail. Anyone seen that in a manual? I can fix stuff without manuals, but it's definitely more time consuming, especially when trying to identify part numbers.
Old July 4th, 2015, 06:24 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
So what are you looking for? that the many online parts catalogs are not covering?
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old July 4th, 2015, 06:38 PM
Give us an example. I can check the green bible and scan the page to show you what it has
Originally Posted by pendy
I'm here for the D's
Old July 4th, 2015, 08:27 PM
Mr Nasty's Avatar
Mr Nasty
james
2005 Td5 110 double cab
Haynes manuals are too general and are vague, they say things such as dissemble engine and reassembly is the reverse, well, great, how about actually detailing what is needed to pull the motor apart properly?
Haven't got any hard copy of any manuals now, all my Land Rover manuals are freely available off the web, RAVE manual is worth getting as are the actual Land Rover ones, they are all free.
For some reason though, the early Haynes manual covering the Range Rover classic is quite detailed but the only engine covered is the 3.5 V8 on carbs, but the rest of the mechanicals are the same or very similar to that of a Defender.
Old July 5th, 2015, 09:17 AM
jgrear
Jason
One example is the bracket for the throttle cable on the 2.5NA. The bracket is at the base of the vacuum pump. One issue with the manuals is that I can't tell which ones people are referring to. For example, what is contained in LHP26? Should I buy it, or is it the same as what I already have? Here is what I have, and none of these seems to contain the correct bracket (BTW, no vacuum pump either):
1. Parts Catalogue Land Rover One Ten 1987 Model Year
2. Military supplement for Land Rover 110 2 1/2 Dielsel 12v~12/24volt (September 1986)
3. RAVE (the workshop manuals seem to only cover V8)
4. Workshop Manual Ninety One Ten (SLR621ENWM), Five Book Sections
5. Land Rover 2, 2A, 3 (“Green Bible” 1959-1978)
6. Land Rover Series III (7 parts, Does not cover the 2.5).
Is the LHP26 manual what I need? Can anyone tell me if it is different from the above, or whether they have something that shows the bracket and/or pump, just as a test for completeness?
Old July 5th, 2015, 01:50 PM
Sorry it turns out the parts catalogs I have are for the defender, and my green bible only covers 2 and 2A (and doesn't have part numbers).
Old July 5th, 2015, 02:02 PM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
Try searching on Guns and Rovers. I know there are a bunch of series /diesel guys over there that might have the info you are looking for.....worth a shot.
Rick
95 P38 "Gus" RIP
03 D2 SE "Fred"
Upcoming 1983 110 Wagon FS ECR For Sale - Vehicles 20 April 17th, 2008 06:19 PM
Build a 110? Chaucer Misc. Chit-Chat 36 March 19th, 2008 08:27 PM
1983 RHD 110 Utility globallandrovers The Vendors Loft 27 February 3rd, 2008 03:31 PM
