180 out - Defender Source
Old April 13th, 2012, 09:29 PM
180 out
Jeez no wonder the lawib was running like shyat. Figured as long as everything was halfway apart, I'd see if my suspicion was correct that I have had the timing fouled up for a long time. How it ever ran at all is a marvel but the fact that I had the diz cranked around must have been enough for it to catch fire. Sometimes I'd just crank away and it wouldn't go and after 20 tries it would finally run.
In addition the oil was all sooty and the plugs black.
Should be all fine and dandy now and maybe even get some better mileage.
Just goes to show you that sometimes, no matter how careful and methodical you are about setting initial static timing, you can blow it.
4.0 timing question bstraw Defender Technical Discussions 1 December 5th, 2008 08:07 PM
yet-a-nother cooling question mattdh Defender Technical Discussions 21 July 19th, 2006 07:11 PM
!&*@! ..... still overheating! jaherring Defender Technical Discussions 63 July 13th, 2006 05:42 PM
Driveline Vibration johare Defender Technical Discussions 20 March 31st, 2006 09:27 PM
Low Beam Headlights Quit JimC Defender Technical Discussions 7 January 29th, 2006 07:54 PM
