15A Fuse keeps blowing. - Defender Source
Old May 11th, 2010, 04:51 PM
KKilo23's Avatar
KKilo23
Kenny
97 D-90 SW
My 15A fuse keeps blowing. I believe it is the one that controls the rear wiper, brake light and turn signals. I have full power when it is blown though, if the fuse blows while your driving the truck keeps running. I replace the fuse and the truck turns over fine.
I think when I put the blinker on it pops it. This past time I put the blinker on to turn right, the fused popped. As I went to put my flashers on to pull over and change the fuse, the flashers flashed for about two seconds then there was a buzzing sound from the center console where the shifter is. Not participially from the shifter but that vicinity. After the buzzing the flashers went out.
I replaced the fuse, the truck turned over no problem. But now I do not have blinkers or hazards.
The turn signal switch still allows me to put the high and low beams on, but nothing when I try to put the turn signals on...
Hazard Switch is completely dead.
Any ideas?
Old May 11th, 2010, 06:09 PM
Uh, yeah you have a short to ground. OK that's obvious I know. Drilled any holes in anything lately? Not out of the question to put a mounting screw right thru a wire that you didn't want to put a hole in. Otherwise I'm "in the dark" like you.
Old May 11th, 2010, 06:28 PM
KKilo23's Avatar
KKilo23
Kenny
No holes drilled at all. No modifications. Just one day started to pop fuses. I would change them and the same issue would occur but everything worked, sorta. The blinkers would work randomly. But most of the time pop the fuse. This time when I hit the hazards caused everything to go out for good.
Old May 12th, 2010, 08:26 AM
Weldon's Avatar
Weldon
Weldon Pundt
"95" D-90
Having a similar issue? Just put in a new dome light now hazards will not work.
Weldon
Old May 12th, 2010, 09:22 AM
KKilo23's Avatar
KKilo23
Kenny
The red arrow is pointing to the slot where the 15A fuse would go that I have to keep replacing.... I am going to try and replace the Flasher Relay today and see if that gets the flashers working, I still need to figure what is popping the fuse.
Old May 12th, 2010, 11:28 AM
Kenny,
If both the hazards & the turns are out I would suspect the relay, especially if you heard the frying relay sound. I managed to get water in my flasher relay in Vt last summer @ Erics 4wheel for Kids event and drove home to Md with no turn signals. I replaced the oddball 1983 hd flasher relay and all was well. Relays are just switches that handle higher amperage-the contacts eventually burn/wear out. I'm having a similar issue with the 130, its randomly blowing the dash/parking lamp fuse when I'm towing a trailer. Went through 3 on a 500 mile trip last weekend.
I'm using the cool new (but very expensive) "Smart Fuse-glows when it blows". Makes figuring out which fuse is blown as simple as removing the fuse cover and seeing what's lit-especially nice after dark....
Old May 12th, 2010, 11:48 AM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
Had same kind of problems. My wire harness inside the frame toward the back of the truck had frayed.
Old May 12th, 2010, 11:49 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Is it a coincidence or does it seems like this fuse is more prone to blowing than other fuses? Seems like a lot of people are having trouble with this fuse in particular. My turn signal/break light fuse also kept blowing repeatedly recently. I removed my town harness and it went away. No idea what caused it but I can only assume that it was the town harness.
When using the turn signals I have noticed that the first flash lights up the trailer light on the dash and the following ones might up the turn signal light on the dash. Is this the way it is supposed to be? Is there something left of the tow harness that needs to be removed (connected to the dash perhaps). Not that is a problem, just thought it was a little strange.
Old May 12th, 2010, 12:01 PM
KKilo23's Avatar
KKilo23
Kenny
Originally Posted by Maryland 110 View Post
Kenny,
I plan on pulling apart the console and changing the relay. If in fact it is just the relay causing the flashers/hazards to be out, great. The real mystery is whats causing the fuse to blow. I do think it has something to do with the turn signals. One thought, the PO had wired a trailer harness off of the OEM trailer harness after it failed, maybe one of those wires are touching and popping it?
Mine does the same. I don't know if this is b/c I have an OEM trailer harness, and some jerry rigged unit by the PO... My luck both my trucks have OEM harness so I can't compare one to the other.
I hope to god this isn't my problem.
Old May 12th, 2010, 11:10 PM
It could be a corroded bulb holder too and that toasted the relay. I would check/replace them as they are a common, very common failure point on 95/97s (which is why I like 1994 lights).
Ron
Old October 1st, 2010, 07:24 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Originally Posted by 130Tdi View Post
Kenny,
Would that be one of the relays behind that metal plate on the fuse panel? I'm looking into this for my issue as well
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old October 2nd, 2010, 05:05 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
It's shorting to ground that's blowing the fuse. Look for a wire thats frayed possibly going through a bulk head or body work or the wiring running along inside the front wing to the turn indicators & repeater on the side of the wing.
With a wiring fault you just have to be methodical and assume nothing. start at one end of the loom and work along. They can be very tough to track down especially if intermittant
Mike Hammond
Old October 2nd, 2010, 06:18 PM
HeloBubba's Avatar
HeloBubba
Chris Murphy
'89 127 (D130), '16 LR4
The wierd noise from your center console/shifter area may be the shift lock solenoid (allows you to shift out of park when you press the brake) trying to actuate as the fuse blows. You have a '97, so I'm assuming you have an auto box.
I had the same thing happen to me several years ago on mine when I was working wiring. One morning while driving to work and stopping for breakfast, I would blow a fuse when I touched the brake when I tried to restart it. Even if I got the car to start by not touching the brake, the fuse would blow before the solenoid would actuate (as I had to press the brake to shift), so I couldn't get the transmission out of park. I figured it was probably brake light related, and after checking all lower lights with no joy, I eventually discovered that in my case it was due to bad luck and stupidity on my part.
I'd removed the upper top door brake light wiring to replace my rear door a couple of days prior, and had not yet reinstalled it. As such, that wiring was wrapped laying in the back rear corner of the truck, with the ground and hot leads isolated from one another. What had happened in that case was that during some random bump or turn, the hot lead had shifted in the back and came to rest against the rear cage upright. Hit the brakes and instant short to ground and blown fuse.
You certainly have a short to ground, and I'd check chafing against the chassis or something similar, but one of the numerous lighting runs or bulb holders, etc/ would be my first path of failure to check, just as the other guys mentioned.
Good luck! Rover wiring t/s is fun.
Murph
Chris Murphy
'89 D130SW
'86 D110 3-door
'89 D110SW
'16 LR4
Former:
'97 D90SW - SOLD SEP '14
'94 D90ST - SOLD MAY '13
D90s sold while assigned overseas. You're welcome America!
'06 Range Rover Sport Supercharged
'8X FankenRover D100
Old October 2nd, 2010, 06:24 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
Why not check all the rear lamps for water. The rears seam to collect fluid inside and corrode the bulbs and fittings.....causing a constant arc. We(Stealership) were told to drill a small pin-hole in the bottom of the lense so if water got in it would drain right back out. I can't count how many I've found over the years with fluid inside of them and it causing all kinds of havac on the electrics. Just something to check before you go tearing into the dash. Good luck.
Old October 4th, 2010, 10:08 AM
Kenny was having this problem again this weekend . Fuse only pops when he uses his turn signals. Pretty sure one of them has water in it after Thursdays deluge.
Old October 4th, 2010, 12:08 PM
KKilo23's Avatar
KKilo23
Kenny
OK, so left turn signal works perfect. Right was blowing the fuse... I have found the issue in the back right wheel well. The ground was frying out from getting wet/dirty/muddy etc etc. So its fixed....until next time.
Also, I originally had OEM trailer harness that was corroded to shit that caused the initial problem. I removed the unit and cleaned it all the wires back up. It apparently was not water tight. This weekend plenty of shit got in there which caused it to fry out again...
Old September 14th, 2011, 01:16 AM
blenkush's Avatar
blenkush
Severin Blenkush
97 D90 LE, 10 Lotus Exige S, 05 LR3
15A fuse problems
On my '97 I've had the 15A fuse blow a few times over the last three months. As Murphy would have it, I'm now almost 400 miles from home and the fuse has gone from blowing after driving a while to blowing as soon as I turn the key on. If I turn the key very quickly I can get the motor started before the fuse goes. I have an electronic brake control for a trailer installed and when I manually energize it the transmission lock soleniod releases so I can shift into gear (thank God - but driving with no brake lights is NOT good). The brake lights also come on when I engergize the brake control. The hazard lights work. I changed the rear brake/tail light bulbs as the housings had filled with water at one point (the leads had some corrosion, but not enough to stop the bulbs from lighting). I also swapped out the relay on the rear wiper with no success. There must be a short somewhere, but with the lights coming on with the electronic brake control my guess is that the short isn't in the rear of the truck. I'm at a loss to think the trailer connection (wired into the factory plug by the gas filler) would be causing this as the fuse blows as soon as the key is turned, not when the brake or turn signal is applied (don't remember there being a "live" wire to the plug but haven't verified). I don't have the luxury of time, so I'm open to suggestion where to look first. Thanks in advance!!
Cheers,
Severin
Old September 14th, 2011, 08:22 AM
The Dro
Dro
1988 Ninety
Cheers,
Severin
Stop using the ebrake to light the brake lamps. You will overheat the cable and potentially burn something.
The hazard light is a different circuit.
Y
ou are back feeding the brake lights via the brake controller. (and the locking solenoid).
The corrosion on the leads can be your problem.
The light bulb can handle the overcurrent for a short period of time. That's why the are are working now.
Old September 14th, 2011, 08:42 AM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
That's one reason why I eliminated that trans lock solonoid.
Old September 14th, 2011, 09:08 AM
blenkush's Avatar
blenkush
Severin Blenkush
15A fuse prob
Roger that on the brake control. I'm only using it to get the truck in gear.
Wouln't corrosion on the light sockets cause the fuse to blow when the brakes are applied? My fuse blows as soon as the key is turned?
wing
Fuse keeps blowing (Electrical short) redrockrover Defender Technical Discussions 7 April 19th, 2010 11:45 AM
Fuel injection system Maxi fuse blowing ? TND90 Defender Technical Discussions 4 August 24th, 2009 12:32 PM
Repeatedly blowing undehood 30A fuse Hans Defender Technical Discussions 1 September 6th, 2005 04:24 PM
Blowing wiper/speedo fuse like crazy....help! P1CR Defender Technical Discussions 4 March 11th, 2004 03:23 PM
