14CUX Diagnostic Tool? - Defender Source
Old August 29th, 2013, 02:56 PM
tomdavey_III's Avatar
tomdavey_III
Thomas Davey
1994/Defender 90
Can anyone recommend a good, affordable Diagnostic Tool for a 14CUX ECU equipment Land Rover?
Old August 29th, 2013, 02:59 PM
Search RoverGauge
Old August 29th, 2013, 03:02 PM
Originally Posted by rijosho View Post
Search RoverGauge
Software free ... just needs a cable made up ...
Old August 30th, 2013, 09:15 AM
tomdavey_III
Thomas Davey
1994/Defender 90
Does RoverGuage work on a MAC?
Old August 30th, 2013, 09:22 AM
not out of the 'box'. I would suggest just borrowing a windows laptop ...
Old August 30th, 2013, 09:23 AM
tomdavey_III
Thomas Davey
1994/Defender 90
I've got one of each, just making sure that Windows was the right choice. Thank you again!
Old August 30th, 2013, 09:25 AM
http://www.amazon.com/USB-Header-Lik...ef=pd_sxp_f_pt
you'll need one of these
and a connector for the ECU cable .... I have a spare although you could just push the wires in initially
Old August 30th, 2013, 09:29 AM
look at the 14CUX pdf i posted yesterday ... it will help you make sense of the readings ... also read this which is for a different product ( I have this as well ) but contains lots of useful info ...
http://ecumate.com/docs/Ecumate%20inst.pdf
I should ask what are you trying to measure?
Old August 30th, 2013, 09:31 AM
RRCs have several of these connectors on them if you have a junk yard nearby. Worst case I can send you one.
I bought a cheaper USB cable that should work but haven't gotten around to trying it yet. If it works, we can get them for $8 instead of $20 and I plan to make up a few and offer them for sale at cost.
http://www.ebay.com/itm/FTDI-FT232RL.../171025576552?
It took a while to ship but if interested I can give it a try sooner than later.
charles
Originally Posted by pendy
I'm here for the D's
Old August 30th, 2013, 09:32 AM
tomdavey_III
Thomas Davey
1994/Defender 90
Yeah I read through this yesterday. A lot of good information, sure wish Steve could ship to the states.
------ Follow up post added August 30th, 2013 08:39 AM ------
Just trying to see all available live data (since check engine light is not illuminated) to help pin-point an issue that I am having (similar to other threads on this site) dealing with Hard to Start, Stumbling, Stalling, wants to die when ramping-up the throttle from idle...
Old August 30th, 2013, 09:47 AM
I had him ship to a UK address and then had it forwarded by a family member.
I had a little bit of fun as it was picked up in a scan at customs and had to complete paperwork specifying what it was. took a little while but no real drama.
I have both ECUMate an Rovergauge ... I have the ECUMate in the truck all the time and used it troubleshoot a few problems ... to be honest I think that the RoverGauge is a better option ... it's far cheaper ... has the same functionality ( even slightly more ) and is upgradeable.
I'm with Charles ... we should create a set of cables and a wiki for using rover gauge ...
Old August 30th, 2013, 09:50 AM
sticky IACV ... give it a good clean and light lube.
Check all your air hoses with carb cleaner.
Rover Gauge or ECU mate isn't going to help too much with this problem unless it's in limp mode because a defective sensor.
Old August 30th, 2013, 09:54 AM
There is already a google code page for RoverGauge which includes a wiki. The best thing we can do is support Collin by contributing to the project directly. If we can't edit the wiki pages directly we could feed him content until he gives us permission
Old August 30th, 2013, 10:00 AM
Charles ... How about we make up a set of cables ... I can actually solder pretty well ... sell them via a sticky and add a premium which is a donation to Collin .... I'm out for a couple of weeks ( getting married ) but happy to work on this when i get back ... assuming my fiancee doesn't change into a dragon during the ceremony! ;-)
Old August 30th, 2013, 10:02 AM
tomdavey_III
Thomas Davey
1994/Defender 90
I've cleaned the IACV, didn't lube it (will do that). the only vacuum leak that I have been able to find was a bad vacuum advance. I have an IGN AMP Module & Vacuum advance coming. Should I replace the Plastic Distributor Insulating cover under the rotor if it is cracked and has a chunk missing?
Old August 30th, 2013, 10:13 AM
Is the broken chunk under the cover causing the advance mechanism to be sticky? Probably worth a look. If it's all clean I wouldn't worry. Mines cracked and causes no issue.
Is the timing set correctly? I found mine was obviously set by some retard with the vacuum advance still connected .... this could make a big difference to pickup.
Old August 30th, 2013, 10:28 AM
charles
Charles I'll take one
Old August 30th, 2013, 12:30 PM
tomdavey_III
Thomas Davey
1994/Defender 90
No, not sure where the broken chunk ended up. I did take the distributor apart to make sure it wasn't down around the counter weights in the bottom.
------ Follow up post added August 30th, 2013 11:31 AM ------
I'll verify the timing after I get my parts and put the distributor back together.
Old August 30th, 2013, 12:37 PM
Me too.
Series Rover Diagnostic Tool slorocco Series Technical Discussions 2 December 5th, 2012 09:59 AM
Autologic Diagnostic Tool For Sale Giffstone For Sale - Parts 2 February 9th, 2008 02:43 PM
ECM diagnostic output/interface on '94 jaherring Defender Technical Discussions 0 April 12th, 2005 09:48 PM
What's In Your Tool Kit? javelinadave Misc. Chit-Chat 18 May 6th, 2004 08:26 PM
Defender 110 and 90 tool kit mpodgorski For Sale - Parts 5 May 4th, 2004 09:17 PM
