14 CUX diagnostic computer (cheap) - Page 2 - Defender Source
View Poll Results: Interest in group buy
I want an ECUMATE! 8 72.73%
I want a cable to roll my own with libcomm14cux 3 27.27%
I have an ECUMATE! 1 9.09%
Multiple Choice Poll. Voters: 11. You may not vote on this poll
Old May 16th, 2012, 11:15 AM
Originally Posted by cgalpin View Post
I added a poll to see if there is interest in either path. I think either is an awesome idea, but I'd prefer integrating it with an onboard computer over a hand held reader. I bet this will help me determine why i get crap fuel economy.
I'd consider making up some cables if there was interest, but I suspect after buying the TTL-232R-5V , 5-way 3mm TTS plug, 400 ohm resistor, and shipping fees both ways, it's going to be closer to $35/40 each so I wouldn't choose this option because of the cost.
you have an onboard computer?
------ Follow up post added May 16th, 2012 11:16 AM ------
can you add poll option for i have an ecumate! ?
Old May 16th, 2012, 11:23 AM
Not right now but I plan on it. A sheeva plug (or pogo plug) has a low enough current draw that I think it could be left running 24x7 and not drain the battery enough to care, but also be configured to auto boot and shutdown as needed with the right power supply. If you add in wifi you can run a tablet or phone as a head unit that can boot quickly (and be put away easily for safety), or you could run a usb based touch screen. But with wireless the head unit would only need power and interact with the main computer over wireless. The main computer can be kept dry and concealed and all the wiring can be run discretely. That's the plan anyway
Originally Posted by pendy
I'm here for the D's
Old May 16th, 2012, 10:03 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Charles, I'm definitely going to make one. Let me know I'd you want "in". Depending on the price of that TtS plug, I might go a different route though.
In exchange, you work in getting a software solution that will work on the Mac! [[actually, might be easier that it looks, I got GIT + Xcode + that QtSDK installed today; will try to compile the libs + widget tomorrow]]
MonLand
1995 D90 NAS
1996 Discovery NAS
Old May 16th, 2012, 10:07 PM
can we also add pool option for "I have no idea of half of the terms used in this thread"?
Old May 16th, 2012, 10:16 PM
Yeah I'm definitely doing one. The the plug is looking tough to find so it might just be best to put in something more generic. Don't go buying without talking to me.
I looked at the source and contacted the author before spending too much time on changes to make sure he's on board. He says someone else is already looking into it. It looks relatively straight forward, the hard bit being some OSX specific code to set the non-standard baud rate and some other serial io stuff. I am guessing that 99% of the rest of the stuff currently #ifdef'd for linux will be the same for the mac. I do want to get it to run on a mac, but I'll likely deploy on linux.
Old May 16th, 2012, 11:33 PM
Welcome to pandoras box ... As soon as you start seeing the real sensor values ... Everything gets weird!
------ Follow up post added May 16th, 2012 11:43 PM ------
In which case you can just borrow mine ...
Old May 17th, 2012, 12:04 AM
Maybe a source for the plug here ...
http://www.automotivewiringsystems.c...g-51155224.htm
Old May 17th, 2012, 12:03 PM
Nice catch! I asked Colin to confirm (the libcomm14cux guy) and he concurs. He says these were used by Bently too
http://www.bentleyparts.com/PRD_Prod...3&prodid=48089
Loic, let's talk tonight about putting in an order.
Old May 17th, 2012, 12:28 PM
I'll take a couple if you are placing an order... i might have some time to home-brew something ... i'd still like an arduino based tester ... i like the idea of it sending my throttle position output to twitter! ;-)
Old May 17th, 2012, 12:30 PM
Ok.
Here is what I think we need - an arduino based 14cux2odbdII converter. Then you open up the world of obdII resources to use with the data.
Old May 17th, 2012, 12:40 PM
yep ... just the libcomm14cux that runs on arduino would open up a whole world of fun
Old May 17th, 2012, 12:50 PM
robertf
Robert F
1995 Discovery
Post up if you are able to get a response from those companies. I have not had any luck with those places listed so far, been using alligator clips so far.
It looks like arduino is just a simplified atmel setup, thats what my last serial comm to bluetooth was based on. Just need one that has 2 UARTs
Old May 17th, 2012, 01:48 PM
I bet the TSA love you!
Old May 26th, 2012, 06:33 PM
http://www.defendersource.com/forum/...d.php?p=350779
2 More 14 CUX 4.2 ECU's eliaschristeas For Sale - Parts 7 October 11th, 2010 07:14 PM
14 CUX performance chip pendy For Sale - Parts 0 May 23rd, 2008 11:12 AM
ECM diagnostic output/interface on '94 jaherring Defender Technical Discussions 0 April 12th, 2005 09:48 PM
d90 makes me ask this needed computer help question paulb Misc. Chit-Chat 5 April 7th, 2005 04:01 PM
Need a DEAD EFI computer for parts Hans Wanted 0 December 5th, 2004 03:21 PM
