12v Power source for Hellas - Defender Source
Old January 10th, 2010, 11:07 AM
tebby's Avatar
tebby
Justin Tebbenkamp
95 D-90 ST
Where's a good 12v power source in the engine bay. Don't want to connect to existing lights! Or would it be best to run to the battery? thanks....j
Old January 10th, 2010, 12:13 PM
I would run the wires back to the battery. You have to pull wires into the cabin anyways for the switch.
Old January 10th, 2010, 12:25 PM
100% agree with woldd90. Run your power straight from the battery and don't forget to shield the wiring.
Old January 10th, 2010, 01:18 PM
Get yourself a distribution panel for you accessories to keep your wiring to the battery clean. Search for blue sea here for the kind most people get. I can't recall the model I have.
Originally Posted by pendy
I'm here for the D's
Old January 10th, 2010, 07:28 PM
tebby's Avatar
tebby
Justin Tebbenkamp
95 D-90 ST
charles...is this what you're talking about http://bluesea.com/category/5/21/productline/126
if so I guess I should get the 12 vs 6 circuit?
Old January 10th, 2010, 09:00 PM
Yes thats it. Count the number of devices you might have, but I went with the 12 just to be safe.
Old January 10th, 2010, 09:09 PM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
I ran mine right to the battary. I like this better because you can run them anytime because they aren't wired inti the lights. I used the hella 4000 wireharness...had a relay but I can't remember if it had a fuse or not.
Old January 11th, 2010, 02:50 PM
tebby's Avatar
tebby
Justin Tebbenkamp
95 D-90 ST
Does it matter if I have a neg bus or not? As far as a neat/clean factor I guess it would it be better to run the grounds back to the neg bus on this vs just anywhere?
Old January 11th, 2010, 03:10 PM
I use the negative bus and run a ground wire back for everything.
Old January 11th, 2010, 04:40 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
As we are into this, what section (square mm) of wire i
should use to supply Hella 4000 euro beam ?
- Charles Eames
Old January 11th, 2010, 05:25 PM
I believe those are 100 watts, so 100 Watts/12 Volts = 8.33 amps
According to this chart, I would use 12 AWG or thicker when using 10ft as the one way length from the battery to the lights.
http://www.powerstream.com/Wire_Size.htm
This chart gives the cross section size of the wire as well if needed.
hth,
charles
Old January 11th, 2010, 06:46 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
I ran mine straight back to the battery on my series III so I could use them all the time. Then this one time while I was at knotts Berry Farm with the cat in the car (too lazy to drive all the way home to drop him off) he put his paws on the dash to look around I guess and flipped the switches on. The plastic covers melted off the lights. For some strange reason I was compelled to go back to the truck after walking halfway just to check up on him and thats when I knew what he must of did. Luckily because I came back the batteries didn't die. I still miss that cat.
Robert Deniro
D90 in Reno, NV with D-90 Source sticker Glenn_Guinto Misc. Chit-Chat 2 September 16th, 2005 09:47 AM
Loss of power Leadfoot Defender Technical Discussions 4 January 28th, 2005 03:36 PM
Power Radio Antenna Kimos Defender Technical Discussions 0 October 21st, 2004 08:45 PM
Power Windows (was: Leccy Windows!!!!!) P1CR Defender Technical Discussions 21 February 28th, 2004 01:14 PM
