12j to 200 tdi wireing ? - Defender Source
Old November 22nd, 2017, 04:39 PM
supertreeman
Nick C.
1985 D90 2.5NA
When changing from 12j to 200 tdi does the wiring need to be updated to account for the additional capacity of the 200tdi alternator? If so does this mean the entire loom or just whatís in the engine bay?
Old November 22nd, 2017, 04:45 PM
No. The alternator wiring is part of the engine loom, which you should get with the engine.
Old November 22nd, 2017, 04:59 PM
supertreeman
Nick C.
1985 D90 2.5NA
Does this mean all the wires in the dash, etc too or can all that stay as is?
Old November 22nd, 2017, 05:09 PM
Naplm00
Matthew
Unrelated to your wiring question but when you get your engine I'd suggest taking a long hard look at the rear main seal T seals and engine block gasket. If you see any weeping but time to replace them as before you put the motor in
Old November 22nd, 2017, 05:20 PM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
you will be able to use the existing wiring for the dash instruments & warning lights, the engine wiring loom is different and should come with the engine but is easy to replicate, you may find it is a good idea to replace the alternator cable to a bigger cable anyway as you may find the existing wiring insulation has gone brittle and is cracked the same goes for the glow plug wires.
The wiring in the dash really has nothing to do with the engine or the charging system. the stock 200TDI uses a different glow plug control, but that is a standalone wiring harness.
A lot of how well a conversion is performed depends on the details of all the parts that you get.
Old November 22nd, 2017, 05:26 PM
supertreeman
Nick C.
1985 D90 2.5NA
Thanks for the responses. This totally answers my questions. Much appreciated.
Engine coming from Rover Rescource and is a fresh rebuild with all new seals, etc.
Old November 22nd, 2017, 05:30 PM
What I'm getting at is that beyond the wiring and the engine, there is a lot of stuff that you should be getting if you want a pain free conversion. A lot depends on whether you are getting a Defender or Discovery engine.
Old November 22nd, 2017, 09:02 PM
you can use the 12j engine wiring harness on the 200. The stock defender 200 tdi alt is a piece of crap just like the 12j one-45 amps. No wiring upgrade needed.
Swap 200 Tdi woth a BMW or Mercedes engine lakis Defender Technical Discussions 20 December 13th, 2015 11:37 AM
Engine Swap: which one? 200tdi, 300tdi, or something I dont even know about gonzanc Defender Technical Discussions 46 April 2nd, 2013 09:36 PM
200 tdi defender for trade pendy Defender Technical Discussions 4 May 1st, 2012 11:26 PM
thinking of buying 200 tdi Defender discotdi Defender Technical Discussions 3 August 27th, 2010 01:25 PM
