110 Wheel Cylinders - How often do they fail? - Defender Source
Old March 5th, 2005, 12:24 PM
COSteve
Steven Reed
93 Defender 110 - #107
Have replaced Rear Wheel cylinders two times in three years. First time with OEM, next time with Genuine Parts (Dealer did the work) and now the Right rear is leaking again. Is this failure rate normal, and is rebuilding the cylinders worth the effort? Thanks! COSteve
Old March 5th, 2005, 02:07 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
I have gone through 4 wc's in 15000 miles, THEY SUCK! I am doing research on the disk brake conversion. The drum or dumb brakes are the worst design I have had the pleasure of owning. The last set of wc's I bought from the UK & I can't remember the make. I also bought rear shoes from the UK as they were only 200$ cheaper than I found here [1996]. I know this will make you fell better!! HEHE
The disk convert ain't cheap! I think buying the axle shell is the cheapest route I have found. George at rds has axles for 1700. I think our axle is worth 0$. sorry to end GTG!
Old March 5th, 2005, 11:16 PM
surf110's Avatar
surf110
Ze
130 Project
I did the disk brake conversion. RN has a conversion kit where you use your existing axle shell for around $2k.
Old March 7th, 2005, 01:59 PM
rolaro
Jan-Dirk Roodbol
1985
help me out, who /what is RN? do they have a web-site?
Thanks in advance.
cheers.
Old March 7th, 2005, 02:06 PM
Rovers North http://www.roversnorth.com/
Old March 8th, 2005, 09:23 PM
COSteve
Steven Reed
OK, second part question.... If I don't drop the 1995.00 at Rovers North, should I be rebuilding them or just replacing them..... (the wheel cylinders) COSteve
Old March 8th, 2005, 09:29 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
The rebuild is cheap! & pretty easy! The hardest part is getting the springs on the shoes. Unless you have a device to spread the shoes. Call George at 504) 248-5301 He will set you up!
Old March 11th, 2005, 04:27 PM
LRover's Avatar
LRover
J. Michael McCaig
I don't know if the later models care about what kind of break fluid is being used (Series vehicles could only use Castrol) but that might be the problem. Flush the brake system with Castrol brake fluid which will also help get rid of rust and moisture. You can rebuild the cylinders if they are not scored. Just take the rubber cups to a good auto parts store and they can match them up. Non-Rover cups usually don't care what kind of brake fluid you use because they are synthetic rubber instead of natural rubber.
110, wheel
Build a 110? Chaucer Misc. Chit-Chat 36 March 19th, 2008 08:27 PM
UK land rover steering wheel mpodgorski For Sale - Parts 2 February 1st, 2006 09:56 PM
