110 tried almost everything and it is still overheating.need some advice - Defender Source
Old November 9th, 2004, 05:20 PM
draaronr's Avatar
draaronr
Here
LR3
3.5 liter 110 started to run hot. I replaced the thermostat (there wasnt one in there so I believe this was a problem in the past.) Evidence that the head gasket was bad (imagine that in a rover) so I replaced that and had the heads cleaned and pressure tested. replaced with composite gaskets. The sleeves in the cylinders were maybe a 16th on an inch dropped which I didn't think was enough to cause a problem. the water pump had been rebuilt poorly so I put a new one on. The temp switch is new. The radiator was rotting so I put on a new core. Now it idles fine for like 15 minutes then the guage creeps up. As the guage creeps up it begins to blow antifreeze out the overflow tank. Is the only thing left the block? Advice would be appreciated.
Old November 9th, 2004, 05:32 PM
Buy pressure tester for the system, the type that you can pressurize the system and make sure that when you pump it up to 15 psi the pressure does not drop. Also check the cap on the overflow tank or replace it. If the system cannot maintain 15 psi then it is running at a lower pressure thus a lower boiling point for the coolant.
Just an idea to start with.
Old November 9th, 2004, 06:01 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Sell it?
To me.
Old November 9th, 2004, 06:12 PM
jabber
m j
110
Diesel Conversion!!!!!
Old November 9th, 2004, 06:57 PM
DBZ2009's Avatar
DBZ2009
Z
ex-1994 D90/ 2 j**ps
Aaron, after the temp creeps back up, does it go back to normal after about 5 mins?
Z
Old November 9th, 2004, 07:18 PM
draaronr's Avatar
draaronr
Here
LR3
thanks Dave. a lot of help, how much you wanna pay?
I want to do a short block on this, but I was wondering what the implications would be of a 4.6 or 4.0 obviously i would like the 4.6, but what will switch over from my 3.5, and what would i have to get new. Also I would like to use my heads and intake, and my edlebrock carb and keep out the electronics. What other problems would arise, Can I keep my lt84 transmission?
No Joe it doesnt come back down. Interesting thing is two months ago that is exactly what it did.
Old November 9th, 2004, 07:33 PM
DBZ2009's Avatar
DBZ2009
Z
yeah i've had this problem for a while. I'm gonna check the block and head gaskets in two weeks and possibly have a larger radiator built. But I think the problem is somewhere in the block, it sounds like that the culprit for you also.
let me know what you find out
Z
Old November 10th, 2004, 03:01 AM
pendy's Avatar
pendy
jim pendleton
89'd90
I got a good used short block if you are interested. 3.9 The 4.0 and 4.6 stuff is harder to find now, so if you do find one grab it up while you can.
JP
legend in my own mind
Old November 10th, 2004, 09:02 AM
souza's Avatar
souza
Dave Souza
1995 Defender 90 SW #275
Aaron, what does it do on the road/highway? If it stays cool, I would say it sounds like the viscous fan. I've had to replace mine as these wear out after about 5-7 years. Perhaps you're running electrics or something else, I don't know about the older 3.5. Or perhaps you should try running electric fans. Also, I've got a 160 thermostat in mine now, instead of the 190. combined with a new viscous fan and a re-cored radiator, I'm running cool all day now.
But Dave might be right, perhaps you should unload that thing, it's nothing but trouble Just call me if you do!
Old November 10th, 2004, 10:10 AM
draaronr's Avatar
draaronr
Here
LR3
Thanks again Dave. It has a new viscous clutch, Not having a thermostat in it when I bought it puts a sick feeling in my stomach, because I think I can read between the lines.
Old November 10th, 2004, 10:22 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I finished a 4.6 conversion in my 3.9 D90. You can reuse just about everything. There are a couple modifications that may need to be done which have all been covered on this board in detail--if you can't find it, PM me and I will dig it up for you.
Have you had the coolant resevoir checked for exhause fumes? I would have that checked out next.
Old November 10th, 2004, 10:58 AM
draaronr's Avatar
draaronr
Here
LR3
Chris I was thinking of the conversion just not sure which engine will cause the least stress and money. I want to keep it carbed for the most part, unless someone can make a valid point to going electric, just feel like if I going to make it electric I might think about diesel. I like the ease of gas, and I am not really concerned with gas mileage.
Old November 10th, 2004, 03:14 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Porous block??? The later blocks 4.0 & 4.6 have caused mucho trouble over here as the milage climbs to around 100,000
Mike Hammond
Old November 10th, 2004, 11:31 PM
draaronr's Avatar
draaronr
Here
LR3
alright sounds like an engine swap in instore from what I read it sounds like for reliability I should stick with a 3.9 over the 4.6. what do you guys think?
also make me a helluva an offer and bring your flatbed and she might be yours.
Old November 11th, 2004, 02:35 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
What? I am curious on the argument of the 3.9 over the 4.6. I love the 3.9 that was in the Defender--it is replacing the 3.5 in my RRC--but I am not going to say one is better than the other. I would love to know why that comment comes into being. Others have stated that the 4.2 is the way to go--mine has 130,000 miles in my Series II Disco--good engine no doubt, but to make those comments, I would ask why. I would love to know. As for the swap, hell, it might not even be necessary--I say this 'cause you don't know what is wrong. If you want a new engine, fine, but from a CB stand point, all you might need is to retard the timing. First I would find out what is wrong. There was another thread, (maybe from Doug???) about him doing a conversion (5.2 or something big???) that had a problem that turned out to be the computer. What if you dropped in the new engine and the same thing happened? First and foremost, figure out what went wrong--then make the decision on how to fix.
Old November 11th, 2004, 09:02 AM
draaronr's Avatar
draaronr
Here
LR3
Valid points Chris, but at this point there is little left, everything has been checked and double checked. I plan to start tearing it apart this week and will pull the block and see what I have.
Old November 15th, 2004, 09:17 PM
draaronr's Avatar
draaronr
Here
LR3
ELCIDd90 it was the block so now i am in the market for a 3.5 or 3.9 block.
Old November 15th, 2004, 10:54 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Could also be a timing issue, running lean.....
Have you totally burped all the air out of the cooling system?
Did you put in a metal or composite head gasket? Also, don't fully torque head bolts 11-14.
Hmmmmm.......
Just thinking out loud here.
-Hans
My oil line fix
My 100k stopped odometer fix
Old November 15th, 2004, 11:04 PM
draaronr's Avatar
draaronr
Here
LR3
triple checked the timing, no air in system, compsoite gaskets torqued to updated lbs.
Old November 16th, 2004, 07:33 AM
DBZ2009's Avatar
DBZ2009
Z
the block...ouch. ever consider putting a 4.6 in instead of the 3.5 or 3.9?
110, overheating
