110 AC problem - Defender Source
Old July 26th, 2004, 03:00 AM
surf110's Avatar
surf110
Ze
130 Project
110 AC problem
Hello,
New to this forum and new to NAS 110s. My AC blows from top and lower vents but not from dash vents.
I've tried moving the lever up, down and in the middle with no success.
Any suggestions would be greatly appreciated.
Ze
Old July 26th, 2004, 12:25 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
Had the same issue. Mine was a deteriorated vacuum line that controls one of the vent doors. They are tiny vacuum lines that connect on top of the AC box, under the bonnet.
Old July 26th, 2004, 01:21 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
Tangential question - can the D-110 in-dash A/C ducting/system easily be installed in a D-90? Could the unique 110 parts be pieced together from parts sold at, say, Rovers North? Does it work well enough if proper additional insulation is installed (I've seen some mention of that)?
Old July 26th, 2004, 01:28 PM
surf110's Avatar
surf110
Ze
130 Project
Thanks Doug. I'll check that out. Did you have to replace the deteriorated vaccum line?
Old July 26th, 2004, 03:43 PM
Doug's Avatar
Doug
Doug Walker
Ze, I cut out the deteriorated section (about 5 inches) and slipped on a larger piece of rubber hose -- snug fit. Just something I had in the tool box.
Jason, I don't think this could be pulled off. First of all, getting the 110 parts would cost you a small fortune IF you could find them, and all the mechanicals would have to go under the bonnet rather than in the footwell. The hvac box (which my insurance company just paid to replace), with the heat exhanger, blower, etc. cost over $4K from RN. And that does not include the dash which would probably cost a small fortune as well.
DW
Old July 27th, 2004, 12:44 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
OK, thanks for the info. Maybe I'll stumble across a wrecked LHD D110 with working AC one of these days while trekking through sub-saharan Africa....
Old July 27th, 2004, 04:10 PM
Doug's Avatar
Doug
Doug Walker
Cancel that ticket! Only 525 Defenders were ever built with the in-dash AC: the '93 NAS 110s.
Old July 27th, 2004, 05:02 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
Not even in the Euro models, eh? Huh, interesting.
Old July 27th, 2004, 09:36 PM
surf110's Avatar
surf110
Ze
130 Project
I saw a 110 in Brazil with the in-dash set up. It didn't look that old. Maybe a 98 or 99.
Old July 27th, 2004, 10:23 PM
Doug's Avatar
Doug
Doug Walker
Maybe dig up that old thread on the CDK that came from Brazil this year for Vegas SEMA show, and look at the interior shots. I seem to remember an 'open' dash with vents...
Still don't believe factory in-dash exists anywhere but NAS...
110, ac
Can you add AC to a 1983 110? aosias Defender Technical Discussions 4 December 13th, 2009 12:07 PM
110 Ac bjf Defender Technical Discussions 57 September 1st, 2009 12:10 PM
Build a 110? Chaucer Misc. Chit-Chat 36 March 19th, 2008 08:27 PM
