10 Spline hallf shaft/CV woes.... need some help - Page 2 - Defender Source
Old June 14th, 2012, 09:11 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by bossman429 View Post
Ok. So basically if I swap everything up to what this picture shows I'm Ok right?
I think that should be easy enough and a days work
Yeah, that's what I was thinking - and you won't have to mess with the RHD steering items.
Seems like it should be straight forward and like you said a days work (although with how it's been so far... ). I'll drop those wrenches/hub socket/etc off later today.
Old June 14th, 2012, 10:37 AM
Sure, you could swap EVERYTHING over and end up with a much weaker system. That is always a good idea...
Old June 14th, 2012, 10:47 AM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
You really do think the AEU2522 is the end all be all huh?
Old June 14th, 2012, 11:16 AM
bossman429's Avatar
bossman429
Adrian
1988 90
Wait I'm confused. I thought you said you use these as tent pegs?
Old June 14th, 2012, 12:46 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
You said they are stronger than the 24 spline stuff but how much more? Yes, the situation he was in, I am guessing a 24 spline wouldn't have been any better (slight downhill with weight on right hand corner and wheel turned) but damn, the CV he pulled was grenaded!
If the 10 spline was more available, I'd could see your point but moving to 24 spline bossman could have things running in a day max. Randy @ RoverBones is close to RC and is usually at the east coast events. I've been looking for a front axle and there are plenty at the bone yards in NJ so I'm sure he'd be able to get one in short time. Hell, if he had a 24 spline setup, he could have used Dana's axle/CV and wheeled for a little while that day.
Another pro-24-spline setup is that it is easier to get an HD diff and axles. And while you are saying the 10 spline CV's and axles are stronger, I could have sworn I read someplace the 10 spline carrier was weaker? I could be wrong tho.
Old June 14th, 2012, 12:48 PM
The 32 spline where is enters the later CVs is smaller than the 10 spline at the diff, so ends up as a weaker drivetrain. In addition the hub bearings are closer together, which is never a good thing.
The 10 spline diff is pretty weak, so should be replaced with a 24 spline and aftermarket 24/23 spline shafts installed.
In the end, both the early and late model axles have weaknesses with the stock late model being somewhat weaker than the early stock axles. They both require upgrading and the overall cost is about the same, although you can skip the CV upgrade on the early ones if you are not that hard core. You can't skip the CVs on the late model axles.
Old June 14th, 2012, 12:54 PM
Originally Posted by don View Post
.... I could have sworn I read someplace the 10 spline carrier was weaker? I could be wrong tho.
Certainly a stock 2 pinion, 10 spline diff is weaker than a 24 spline one but they both fail regularly. The weakest point on the stock early axles should be the diff center and normally is. The weakest point in the stock later ones is where the inner shaft goes into the CV joint.
Old June 14th, 2012, 12:57 PM
Moral of the story. If you have stock Rover axles...carry spare halfshafts and a CV joint. They are cheap out of the UK or used from someone that has upgraded.
Old June 14th, 2012, 01:13 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Ok - so basically the CV joints my truck has/had are stronger than the CV joints on a 24 spline (disco) assembly. However the disco differential is stronger.
am I correct?
I think it comes down to availability of parts mostly. I can get disco axles and CV joints anywhere. I'd rather have a slightly weaker CV joint but the ability to find 3 spares easily then a 10/23 axle shaft/CV joint, which is rarer than dragon shit apparently (down here) and still just marginally better than the 24 spline disco axle/cv assemblies.
I think it makes most sense to swap over the disco stuff in this case....no?
Old June 14th, 2012, 01:15 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
Yea or just swap to HD 24 spline axles, cvs, lockers and gears and call it a day
Obviously I didnt have to change anything to drop it all in my disco but if I had a defender thats what I would do if not the Toy swap like what Don has. The only downside is the hub bearing spacing but does it really matter that much on a D90!? Hell I am sure my disco is MUCH heavier than Adrians d90 and I am running 35's.. No problems as of yet
------ Follow up post added June 14th, 2012 11:16 AM ------
am I correct?
Yes all of the Disco stuff is stronger than the stock 10 spline stuff. Only the AEU2522 is stronger than the disco CV joint but good luck finding replacements for those CV's.
Old June 14th, 2012, 01:17 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Yea i've realized that.
Ok - looks like another fun filled day of gear oil stank is in my future.
Old June 14th, 2012, 01:28 PM
You guys need to learn to buy stuff out of the UK. The AEU2522 aftermarket joints are $30 new.
Old June 14th, 2012, 01:31 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
Yea but they are still going to break on the trail. They are not that much stronger than stock d90 or disco CV's. Guys used to use this upgrade before they made HD axles and CV's now that they make good stuff I'd rather buy that than lose a day of off roading just to replace a broken CV with another one that is going to break...
Not to mention you better be carrying spares at all times because you better believe in the US nobody else is going to be carrying one. As he already found out
Old June 14th, 2012, 02:12 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Another question - how many of those $30 parts are knock offs? I'm sure the metal isnt up to the same standard as LR original.
I just dont feel comfortable buying stuff from the UK, if it can at all be avoided
Old June 14th, 2012, 02:41 PM
Keith Kreutzer has been helping me work through my parts listing for my 10 to 24 spline conversion, and he said that when I get my CV, get the AEU2522. He also said that the aftermarket (which happens to be much cheaper than LR) is going to be preferred because it will be a softer metal (which I take means less brittle).
RR 10 spline diffs. front and rear broadstone For Sale - Parts 2 July 2nd, 2012 09:15 AM
Will Calipers and rotors from a 10 spline D90 work on a Disco Axle tomaco1 Defender Technical Discussions 13 December 14th, 2010 11:16 PM
10 Spline Axle Parts Series / 90 / 110 Wolf Fabrication For Sale - Parts 0 April 6th, 2010 06:25 AM
10 spline Series 2/2a/3 axles (3 sets) Seriesman For Sale - Parts 0 October 25th, 2004 12:53 AM
