1 or 1.5 inch lower upper shock mount? - Defender Source
Old February 8th, 2011, 10:37 AM
Santiago
Santiago Gigola
Anybody knows if there is an upper shock mount (available on the market to buy straight away) that lowers the upper rear shock mount in a Defender about 1 inch (or 1.5) instead of two?
I know of the Expeditionwear and Terra Firma ones sold at Expdition Exchange and Roversnorth but is there one that just lowers the moun 1 inch (1.5 is even better) instead of two?
The thing is I need to install my new Koni Raid shocks in my Defender 110 and it is lifted 33 milimeters so I need to lower the upper shock mount a bit in order not to loose to much droop.
Stgo
Old February 8th, 2011, 11:02 AM
do you have a longer bumpstop too?
Old February 8th, 2011, 01:57 PM
Santiago
Santiago Gigola
Yes Ren, I have the bump stops sorted out.
They have been extended 40mm, so that the shocks do not bottom-out on compression.
The problem with the upper shock mounts is that I believe that if I lower them 2 inches (aproxim. 50mms) then I will probably have problems on compression since the Koni Raids are longer that the standard shocks I have now. That's why I want to lower the shocks just what is necessary and no more than that.
mount
rear upper shock mount thread Abrooks Defender Technical Discussions 2 January 10th, 2010 11:10 PM
shock mount redrover Defender Technical Discussions 9 January 19th, 2006 08:22 AM
Rovers North 1.5 inch lift kit w/shocks Seriesman For Sale - Parts 1 August 26th, 2005 11:45 PM
For Sale: Mantec Steering Guard, NSO Rear Shock Mount, Hinged Radius Arm Doogs For Sale - Parts 8 January 26th, 2005 11:28 AM
Scorpion racing Rear upper shock mounts for stock trucks! dmarchand For Sale - Parts 2 July 8th, 2004 12:57 PM
