1.410 or 1.22 Transfer Case Question - Page 2 - Defender Source
Old May 15th, 2014, 02:34 PM
winn442's Avatar
winn442
Winn Bearden
Originally Posted by diesel_jim View Post
I have a 1.2 on my 110 (Td5, tweeked, standard gearing otherwise, and 235's)
Pulls very well. 1st is slightly overgeared, but nothing bad. If it stick my 255's on, then 1st does become pretty useless for steep hill starts, but it takes all of 2 seconds to slip into low range, pull away in 2nd low, then shift straight into 2nd high. easy.
When I towed my new G wagen back last month (SWB 280GE is anyone's interested... my next project!) I had to use low a couple of times on hillstarts even on 235's, but once I was moving it was no problem.
Mind you.... even a SWB G comes in at about 2300KG!!!
I've got the same problem, running a tweaked Td5 90 with a 1.2 on 35's. 1st sometimes is a little overgeared, like stopped on a hill with the A/C on. After 1st, there's no problem whatsoever. MPG on the highway is awesome, and I'd hate to lose that by going to 4.11's or a 1.4 box. If I could put in a taller 1st gear in that would be perfect.
Winn Bearden
transfer case
1.410 or 1.22 transfer case with 200tdi conversion akrockhound Defender Technical Discussions 19 January 8th, 2013 01:15 PM
transfer case questions HELP! mattwhite Defender Technical Discussions 2 March 8th, 2009 02:45 PM
Transfer case output nut size? Trigger Defender Technical Discussions 5 April 12th, 2005 03:32 PM
transfer case redrover Defender Technical Discussions 9 January 27th, 2004 02:41 PM
looking for a Transfer Case for '94 D90 rover_rich_d90 Wanted 5 November 12th, 2003 06:46 PM
