1.2 vs 1.4 in a 110 Double cab - Defender Source
Old October 13th, 2015, 09:14 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
I was thinking about getting a rebuilt tranny and T/C for my 110 and was thinking about switching to a 1.2 ratio.
I live on flat land, take the truck on the beach once in a while, other than that I'm pretty much a poser. 285 75 16s, 200tdi, lt77, really looking for more on the upper end on the highway, thoughts?
was going to do the frame swap first, but its near impossible to get Richards to return my emails.
Old October 13th, 2015, 09:40 AM
The taller tires are already helping. What is the engine revving at on the highway right now? You need to keep it in the sweet spot otherwise you'll be changing down all the time.
Old October 13th, 2015, 09:48 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Jonesy, went from 1.4 to 1.2 with the same exact set up this past weekend. He seemed thrilled with the results on the upper end.
There's a long thread that started Sat at about 8am and sign off at about 3am Sunday.
Old October 13th, 2015, 09:58 AM
Which exact LT77 do you have as that makes an impact? There are different gear ratios. Do you have the fueling turned up?
Old October 13th, 2015, 10:46 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
thanks
ill look for it
Old October 13th, 2015, 10:49 AM
1of40's Avatar
1of40
1of40
Originally Posted by tomaco1 View Post
thanks
ill look for it
BTW, as Red90 said, the version of LT77 can be important. I believe if you have a G or H suffix LT77 you should be better off than earlier suffixes.
Old October 13th, 2015, 10:50 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
late lt77 and the fueling is only up a bit, conservative due the fact i haven't installed the egt on it yet
it does have the upgraded intercooler, stock location, fatter allisport
Old October 13th, 2015, 10:54 AM
late lt77
Need to know the prefix to determine gear ratio (the first two numbers in the serial number). The suffix is more to do with the strength of the internals.
Old October 13th, 2015, 01:41 PM
My r380 experience might not be relevant, but I have 1.2 behind a 300tdi in the 90 and 1.4 behind the 300tdi in the 130. The 130 outperforms the 90 in every respect. The 1.4 is the right ratio when you compare the two side by side.
Old October 13th, 2015, 01:51 PM
Originally Posted by JimC View Post
My r380 experience might not be relevant....
At this point, I "assume" that he does not have an LT77S (that came with the 200TDI) and thus has the 0.83:1 5th gear instead of the 0.77:1 that you have. This makes a huge difference in highway driving. Switching to 1.22 helps a lot. The downside is 1st becomes a bit high for a 110 unless you have the military ratios. This is why my suggestion is always to use the boxes that came with the engine.
Land Rover Gear FAQ
Final Drive ratios in 5th gear:
Pre-200TDI LT77 and 1.22 LT230 = 3.59
300TDI R380 and 1.41 LT230 = 3.84
Old October 13th, 2015, 02:50 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
I'm gonna take a look at the serial number tomorrow
Old October 13th, 2015, 04:40 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I never liked the 1.2. Starting off on a hill is really noticeable.
Legend in My Own Mind.
Old October 13th, 2015, 05:47 PM
Low range?
Old October 19th, 2015, 03:04 PM
Old October 19th, 2015, 03:43 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Originally Posted by Rocky View Post
Low range?
Chris:
Low range doesn't change when you swap a T-case.
We're only talking high range here.
RDavisinVA
Old October 19th, 2015, 04:19 PM
Originally Posted by rdavisinva View Post
Chris:
Chris was meaning to start off in low range on a steep hill.
Old October 19th, 2015, 04:28 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Oh sorry Chris, I sometimes forget myself and then remember.
RDavisinVA
Old October 19th, 2015, 04:39 PM
Talk to Jonesy, pretty much the exact same setup as you describe above but with 235 tires. He just switched from the 1.4 to the 1.2 tcase a week or so ago, and we drove down to URE & back.
Old October 19th, 2015, 04:41 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
you drove to URE, never made it back!!! Motha Licka...
Old October 20th, 2015, 08:51 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
for some reason the trans serial number is very hard to read, it may of come this way, or my kids may have done it while cleaning it up prior to install.
110, double cab
110 Double Cab :: 2013 Land Rover Defender 110 Double Cab Celtic Nomad Defender & Series Truck Registry 0 April 29th, 2015 07:19 AM
110 or 110 double cab wanted gomotomoto Wanted 13 December 8th, 2012 03:11 PM
Tdi metalic blue 110 Double Cab Uncle Douglas The Flea Market 0 May 25th, 2009 10:41 PM
110 Double cab roof rayfi Wanted 0 October 13th, 2008 12:55 AM
110 Double Cab Pickup spoted in West Hollywood Mark M Misc. Chit-Chat 13 August 26th, 2005 12:38 AM
