1.2 or 1.4 Transfer Case? - Defender Source
Old September 16th, 2013, 04:28 PM
UtahD90
Adam Harward
1995 Defender 90 SW
Converting my NAS D90 SW to diesel:
Motor: 300TDI
Transfer Case: 1.2 or 1.4 is the question
Diffs: 4.11
Tire Size: 35
What do you guys think? Anyone who's run this set up and has experience I would love to hear. Live in Utah so I will be in the Mountains but don't generally pull anything with my defender and I would say is loaded down (average) Not super heavy.
Old September 16th, 2013, 04:56 PM
I personally can't imagine why a D90 would ever need a 1.4 unless it was just a trail rig, but I don't have a D90, so will defer to others.
Mark Kellgren
KM4BOR
Old September 16th, 2013, 05:01 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Motor: 300TDI
Diffs: 4.11
Tire Size: 35
With 35s a 1.4 would be better at pulling hills and off-roading.
The 1.2 would be OK on the flat with a SWB going down a highway.
RDavisinVA
Old September 16th, 2013, 05:15 PM
UtahD90
Adam Harward
1995 Defender 90 SW
Is that with stock diffs? I've got 4.11's in my diffs
Old September 16th, 2013, 05:20 PM
1.4 vs 1.2 tcase...nothing changes in the "lower" gears (i.e. low vs high). So throw out any considerations that'll make it a better or worse "trail rig" offroad. Only consider highway rpms based on the Tdi you're throwing in.
Old September 16th, 2013, 05:23 PM
1.2 is a good choice with that gearing, especially with a light power tune.
Old September 16th, 2013, 08:32 PM
mine pulls fine with the 3.9 and 255's maybe you all need to spit out the diesel kool-aid and get V8's
Old September 16th, 2013, 08:40 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Rent my
Old September 16th, 2013, 08:42 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I have the same exact setup.
300tdi
35" tires
1.4 t case
4.11 gears
It's perfect
I have built trucks with the 1.2 combined with the 300 and it sux on any hill when you start off. It's good on a strait flat highway but that's about it.
I found that the perfect combo is that I have with the overdrive setup as well. It gives you the best of both world and just a bout as perfect as you can get.
I also upgraded my Intercooler which helps a ton.. If interested in overdrives, turbo kits or intercoolers for diesels, shoot me a pm
Legend in My Own Mind.
Old September 17th, 2013, 12:27 PM
UtahD90
Adam Harward
1995 Defender 90 SW
Thanks for all the comments. I appreciate your input
transfer case
transfer case questions HELP! mattwhite Defender Technical Discussions 2 March 8th, 2009 02:45 PM
Transfer case output nut size? Trigger Defender Technical Discussions 5 April 12th, 2005 03:32 PM
1.4 ratio transfer case dave_lucas Wanted 2 November 13th, 2004 02:16 PM
transfer case redrover Defender Technical Discussions 9 January 27th, 2004 02:41 PM
looking for a Transfer Case for '94 D90 rover_rich_d90 Wanted 5 November 12th, 2003 06:46 PM
