1.2 D2 transfer case into Defender - Page 3 - Defender Source
Old October 28th, 2015, 12:03 PM
jafir's Avatar
jafir
Jafir Elkurd
Am I the only one that just realized that the first page of this thread (which is mine, and admittedly I did not even realize it : ) details how to swap the rear/output stub over (to keep the speedo),
Oops. I should pay more attention.
Old March 11th, 2016, 06:00 PM
DailyDrivenDefende
Michael
1989 110, 1985 90 200TDI
Just out of curiosity, Do D2 or D1 cases have cross drilled input gear?
Old March 11th, 2016, 06:05 PM
96 model year and up do. Not sure about before that
Old March 12th, 2016, 09:26 AM
DailyDrivenDefende
Michael
Thanks for the information. Not trying to bring this back from the dead but thought I'd rather recycle a thread than start a new one.
If I pick up LT230 from disco2 with CDL nipple, it should mate up right? Is there a disadvantage to disco cases? Other than weaker gearing?
Old March 12th, 2016, 11:27 AM
NAS 90's have 1.2 tcases. Same tcase,same gearing. Transfer cases are the same except for some drillings for parking brake mounts and electronic interlock's on dicoveries.
Old March 12th, 2016, 01:58 PM
Originally Posted by Red90 View Post
On mine, I needed to drill and tap a couple of spots for the parking brake cable mounts as well. The switch can remain.
ditto. i have a D2 in mine. remove solenoid, drill/tap for parking brake and install.
Mark Kellgren
KM4BOR
defender, transfer case
Defender Transfer Case Mamba For Sale - Parts 0 May 7th, 2013 12:42 PM
Nylock nut size, rear flange of transfer case - also identify T-case ratio hillstrubl Defender Technical Discussions 3 July 11th, 2012 02:42 PM
Can't get D2 T-case into D1! James Defender Technical Discussions 5 January 21st, 2009 02:52 PM
transfer case . . . transfer Abrooks Defender Technical Discussions 38 October 20th, 2008 09:04 AM
How hard to replace a Transfer case? crash0577 Defender Technical Discussions 1 October 7th, 2003 08:40 AM
