'06 LR3 backup chime problem - Defender Source
Old November 15th, 2012, 02:45 PM
smob's Avatar
smob
Steve
'97 Arles Blue SW #2131
Hi - The alert chime no longer goes off on my 2006 LR3 - the light still blinks, i.e. the park distance sensor still works, but no sound. I'm assuming this is a module/bit of electronics in the dash. Any ideas on the part and how to replace?
-Ren Ching
Old November 15th, 2012, 03:03 PM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
Dumb question but is the chimr on? If you haven't already try pushing the p))) button above the radio. My kids have turned it off in out 3 when climbing around.
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
Old November 15th, 2012, 03:10 PM
smob's Avatar
smob
Steve
Yep, it is - just checked.. but good point.
-Ren Ching
Old November 15th, 2012, 03:25 PM
rover26c's Avatar
rover26c
Lee
1994 D90 ST
Question. How can you tell if an LR3 HSE has a electronic locking rear differential?
Old November 15th, 2012, 03:29 PM
lordhelemt's Avatar
lordhelemt
Paul
If you have nav you can see if your locked on the off road screen. Locked diff was part of the heavy duty package so that may show up on the vin. It also had a full size spare
Old November 15th, 2012, 04:09 PM
lordhelemt's Avatar
lordhelemt
Paul
Sorry I have no idea but when you figure it out please post just in case I end up having the same issue.
how are your lower control arms?
Old November 15th, 2012, 04:53 PM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
A failed PDC sensor can set a fault where you'll get the warning light, but not the chime, or inconsistent alert. We use Autologic which can tell us specifically which sensor, but if you have a stetoscope or even a length of tube, you can hear the individual sensors clicking when you pass over them.
Email is
Same place, new dogs.
Old November 16th, 2012, 01:26 PM
smob's Avatar
smob
Steve
Excellent, thanks, Trevor..
-Ren Ching
Old November 16th, 2012, 01:58 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
I think my front right is going out. I get a clunk when offloading over our massive driveway curb, dirt road washboards, and extreme braking. Doesn't look to be too bad of a job to do yourself. I found lots of good info on disco3 forum. Dealer quoted me about 1100 all in new arms and alignment, but I can get the both sides arms and bolts for like 400 if you don't go genuine. I doubt there are much difference in brands...if they go every 50k don't see why you need to spend 400 an arm for marginally more life if any.
I also recently found out that when parked uphill in the driveway, and its really cold out, like 15 or less, I get some dripping from the electrical connector on the transmission. But if its warm its ok. If I back into the driveway it's also ok, even when cold.
So it seems I have a number of the common nuisance items going on. No sun roof leak, but that's probably because it hardly ever rains out here.
I recently changed the transfer case and diff fluids. Difs were a good idea, they had a bit of metal in them. I used amsoil severe gear.
I also had some mystery noise of change inside. Stripped apart just about everything. Finally found it was a nickel in the heat fins of the amp under the passenger seat. I mistakenly turned the car on with the seat belt unhooked and have to go get the dealer to turn off the airbag light. But at least the rolling change sound is gone.
Other than that I really like the LR3. I get calculated 18-19.5 on the interstate at 75. And 13-15 around town. I find that the trip mileage is off by a couple mpg continently.
Pete
ac, lr3
Wtb 05 or 06 lr3 Campbell Wanted 0 April 12th, 2012 05:52 PM
Wobbly distributor cap? and an update on my starter problem MiniGuy Defender Technical Discussions 6 January 10th, 2006 10:13 AM
Ignition Problem Dfndr90 Defender Technical Discussions 1 November 21st, 2004 08:26 PM
Fun new problem: starter circuit issue jaherring Defender Technical Discussions 1 September 12th, 2004 03:07 AM
on-going electrical problem... vesparover Defender Technical Discussions 3 October 23rd, 2003 11:13 AM
