03 Range Rover HSE Question, Sorry - Defender Source
Old December 8th, 2014, 03:27 PM
RockShow's Avatar
RockShow
Ben Goodwin
1996 D1
Does anyone know anything about a fix for an over-active motion sensor on the Range Rover's alarm system? I remember something about someone making a fix kit on the P38's but I sold mine before it was an issue.
On this one, if you lock the doors sometimes it makes what I can only assume is a quiet warning beep and other times its a full blown alarm. Nothing has touched the vehicle to cause it to sound the alarm.
Any thoughts? Is there a way to turn off the alarm system or disconnect its ecu without causing other issues or warning lights etc.?
Old December 8th, 2014, 03:45 PM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
My P38 will do that if I try to lock and arm it when the sunroof is open. You might have a sensor in need of alignment. Other than that to offer, I'm afraid I would not be of help. I hate electronics and wires.
Black Rhino Lives Matter
Old December 8th, 2014, 03:51 PM
Jackie Treehorn's Avatar
Jackie Treehorn
A
1985 (legitimately)
You definitely need this:
http://www.rswsolutions.com/index.ph...=415&Itemid=81
It's cheap, it works and you will need it for a host of other codes and issues, so get this first.
After you have Allcom, you can turn off and manipulate certain control groups in the Mk3, alarm functions among them.
Old December 8th, 2014, 03:53 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Does the '03 have the same interior acoustical alarm system as the P38? If so, I have had mine disconnected for weeks due to headliner work and haven't had any issues. No codes or dash indicators. Alarm arms and locks work normally as if it were connected. Haven't tried to set it off yet. My .02!
Old December 9th, 2014, 07:55 AM
RockShow's Avatar
RockShow
Ben Goodwin
1996 D1
It's my uncle's car for the moment but he will be tired of it in a few months when one the msgs pops up warning of catastrophic failure and I am going to buy it.
He is going to replace the battery today and see if that helps for now. If that doesn't help I am going to drive up there and wire the bonnet switch to always read closed. Another site listed that as a common cause. If it gets that far he will definitely decide that it has too go. When I buy I will pick up one of those new code readers and see if I can't disable a few of the more troublesome systems; alarm, ride height, speed, abs etc
Thanks for all the help!
Old December 9th, 2014, 10:21 AM
JBurt's Avatar
JBurt
Jesse McCoy
'89 RRC SWB (needs work)
We had something like this on the LR3. I shorted the bonnet sensor with aluminum foil for a quick fix and then shoved some wire and taped it off for a permanent solution. Has worked fine since.
"It's not a Jeep"
Old December 9th, 2014, 12:12 PM
cheers
norman geary
none
Just unplug the bonnet switch 99% this will cure the problem
Old December 9th, 2014, 12:52 PM
petminded's Avatar
petminded
David
1995 Defender 90- Yellow- Soft Top
It's going to take a month to receive a catastrophic failure on a LR? That's news! ;-)
Old December 9th, 2014, 01:43 PM
RockShow's Avatar
RockShow
Ben Goodwin
1996 D1
It only gets driven once a week so I was giving it the benefit of the doubt and saying it could make it atleast two outings without a death warning. But I am a rover's half full type of guy...
It's an 03 and the previous owner and my uncle both never drove it so it only has 30k miles on it. Seems like the perfect candidate for a solid axel swap and the only new body style range I know about running 285/75s with 3" of lift and a full long travel suspension.
I want a do over on my old p38 project. I am a lot handier and have a lot more tools than I did 10 years ago when I set out to make the first lifted "new rover" (97 p38) in the east. The drug dealers in Richmond had to second guess their choice in rims when I pulled up to their blacked out hood rover!
hse, range rover
Range Rover Sport HSE rack question tjfslaughter Misc. Chit-Chat 5 June 5th, 2012 06:27 PM
Off Topic sorry, Mountain biking question merlin8ty Misc. Chit-Chat 38 March 24th, 2010 06:47 PM
tach question, sorry if redundant (warning) Neo Defender Technical Discussions 5 October 7th, 2005 04:24 PM
