03 d2--dead - Defender Source
Old August 16th, 2013, 08:39 PM
Abrooks's Avatar
Abrooks
Tony Brooks
03 d2--dead
My next door neighbor's neice is visiting them from out of state with her newly acquired 03 D2 with 175K miles on it. It "used up" all of it's coolant between southern PA and DC. Apparently this is a common occurance for her. They took it to the local rover shop (overland 4x4) who gave her an estimate of $7000 for a complete reseal of the engine, new heads, various hoses, all of the TREs (which are apparently shot), leaking tcase, etc. Shop says the steering linkage is bad enough that it shouldn't be driven. The owner is threatening to try and drive it back to PA without any repairs. My reccomendation is to nurse it to carmax and walk away from it -- any other suggestions for what to do? Body is ok, interior looks like it has 175K on it.
Old August 16th, 2013, 08:58 PM
87 D110 (Ruby)
Carmax...but they are getting smarter there!!!
Old August 16th, 2013, 09:19 PM
A used engine from Will tillery... A case of beer and 6 pizzas. Invite the HH crew over for a swap.
Old August 16th, 2013, 10:39 PM
Motor reseal should cost about $800 in parts including machining the heads, and can easily be done in two days. Tie rods are expensive, but take about 10 minutes to install. I'd buy the complete assembly with both ends. All Lt-230's leak, so I'd just top it up. If you want to slow the leak significantly you can replace just the input shaft (without pulling the t-case).
Unless they are really attached to the Disco, its probably not worth fixing. I would only recommend spending that much on a really clean truck, regardless of miles.
03 D2, CDL, Rovertym front bumper, 122k: $4500 ECUELITE For Sale - Vehicles 1 December 22nd, 2011 10:47 AM
03 d2 trailer wiring wanted mountainviewrover Wanted 0 December 9th, 2008 05:03 PM
HELP, HELP Dead D90 in CT januconn92 Defender Technical Discussions 16 July 8th, 2005 08:20 PM
Need a DEAD EFI computer for parts Hans Wanted 0 December 5th, 2004 03:21 PM
Water pump pulleys - got a dead 3.9 laying around? jaherring Wanted 3 September 9th, 2004 09:16 AM
