Pelican cooler warped sides? - Defender Source
Go Back   Defender Source > Non-Technical Discussions > Cooking Corner
Old July 23rd, 2014, 12:16 AM
Raz's Avatar
Raz
Leif
1994 90 ST #1589
My Pelican cooler is a year old and I don't remember it looking like this last time I had used it. The sides are noticeably concave. Doesn't look right. Does anyone else see this in there Pelican cooler? They have I lifetime guarantee, but wanted to check with the contingent here before I call them on this.
Old July 23rd, 2014, 01:35 AM
RBBailey
RBBailey
1965 IIa
I've noticed mine bulging out a bit.
I love that thing, went for a week in Moab this spring -- One block of ice, one bag of ice. Still ice in it when I got home.
Old July 23rd, 2014, 01:45 AM
Raz's Avatar
Raz
Leif
1994 90 ST #1589
It hasn't let me down as far as keeping ice over the last year, but thinner sides could mean less insulation and these coolers aren't cheap. I sent the pic to Pelican to see what they say.
Old July 23rd, 2014, 07:41 AM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Mine is not like that. It has been on 20 plus commercial flights.
Old July 23rd, 2014, 09:58 AM
josh-man's Avatar
josh-man
joshua
82 Land Rover 110 Ex MOD
#Shouldaboughtayeti!
Old July 23rd, 2014, 10:01 AM
tjfslaughter
thomas
Burbon
yeah a Vietnamese import that lies on actual size VS an American made product with a lifetime warranty.... Hmm. Oh yeah your selling a yeti with a hot lady inside of it.
Old July 23rd, 2014, 10:03 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Everyone would buy a yeti if they came with a free girl inside.
Follow-up
Josh's pelican that is still at my house is perfectly flat, no warping.
Old July 23rd, 2014, 10:27 AM
josh-man's Avatar
josh-man
joshua
I hear ya. And I'm a support made in the US more than most but I put these two side by side in a 9 month mil trial and the yeti just performed better when it came to ice retention. Yes the yeti latching system is crap compared to peli and yetis have a heavier dry weight but we decided it wasn't worth the compromise.
Bottom line though is they are both light years ahead of what we have been using for years and I'd gladly use either. Even if it didn't come with a cute chick that has an ass that won't quit
------ Follow up post added July 23rd, 2014 10:28 AM ------
Wait, how do they lie on size?
Old July 23rd, 2014, 10:46 AM
tjfslaughter
thomas
Burbon
http://www.pelicancases.com/pelican-vs-yeti-s/141.htm
I never performed the test but apparently if you actually measure the capacity it comes up shorter than advertised. I heard this from one of the competitors, and they use it as a selling point.
Old July 23rd, 2014, 11:27 AM
josh-man's Avatar
josh-man
joshua
Interesting! Our agency has 600 yetis deployed but I'm not at a tactical level anymore to know if they are breaking the latches. Peli is awesome shit cannot ever argue with that.
Old July 23rd, 2014, 07:35 PM
Polyethylene has a melting point of around 240 degrees fahrenheit. The boiling point of water is 212.
At high temperatures, it will easily warp.
The low melting point of polyethylene is its greatest weakness. Next greatest weakness is creep. Otherwise, the stuff is amazingly durable.
Old July 23rd, 2014, 07:56 PM
tjfslaughter
thomas
Burbon
Polyethylene has a melting point of around 240 degrees fahrenheit. The boiling point of water is 212. At high temperatures, it will easily warp. The low melting point of polyethylene is its greatest weakness. Next greatest weakness is creep. Otherwise, the stuff is amazingly durable.
I will have to take a closer look but I don't think they are polywarpathene. I think they are a proprietary mix of glass filled nylon. TPO would be my second guess but I doubt it.
Old July 23rd, 2014, 07:58 PM
Raz's Avatar
Raz
Leif
1994 90 ST #1589
The weather here very temperate. Lowest temp the cooler has seen is 20 degrees. The warmest is 93. The highest altitude is a mountain pass at 3000 feet. Don't know what happened to it, but Pelican said they will replace it no questions asked. But, I have to pay shipping both ways.
Old July 23rd, 2014, 08:18 PM
body polywarpylene
handle tpe
latch abs
failure looks either like heat, or something heavy rested on the top for a long time.
Old July 23rd, 2014, 08:27 PM
tjfslaughter
thomas
Burbon
body polywarpylene handle tpe latch abs failure looks either like heat, or something heavy rested on the top for a long time.
I think it was an insulation failure that led to weakness in the walls makes no sense to use regular poly with the extreme differences between the inside and outside (thermo expansion coefficients between the inside outside..... Or some other nerdy engineering term).
Ok I have to eat crow. It is polyethylene based on the spec sheet. I bet is is a cross linked poly and not regular poly.
Old July 24th, 2014, 03:24 AM
Raz's Avatar
Raz
Leif
1994 90 ST #1589
I just loaded the cooler with ice for the weekend and noticed the back side and top both have similar warping. Also, one plug on the back, likely used to fill with insulation during manufacture, is loose.
There is no extreme heat here in western WA. I think this is likely an isolated issue as no one else here seems to have experienced this, but I'm not sure if I should incur the cost of shipping both ways for the warranty or cut my loses and find a new cooler.
Old July 24th, 2014, 04:28 AM
Elbee's Avatar
Elbee
Lance
1989 110 200tdi
Are the walls supposed to be vacuum sealed? Might of lost seal and possible altitude change made the walls retract slightly.
Old July 24th, 2014, 07:26 AM
Bill Larson's Avatar
Bill Larson
Bill Larson
This is a very disturbing thing...I hope Pelican resolves this.
Old July 24th, 2014, 09:04 AM
Certainly doesn't sound right.
Old July 24th, 2014, 11:20 AM
tjfslaughter
thomas
Burbon
Raz,
I am sending you a PM regarding the cooler.
sides
warped steel wheel fix needed Overlander Defender Technical Discussions 3 August 20th, 2013 01:13 PM
Pelican cooler solarguy The Flea Market 18 May 22nd, 2013 12:28 PM
200tdi oil cooler / oil cooler line thread question dave_lucas Defender Technical Discussions 7 September 26th, 2012 11:56 AM
warped wheel. rover4x4 Defender Technical Discussions 3 August 22nd, 2009 07:16 PM
Hardtop: Body color sides or alpine white sides? evilfij Misc. Chit-Chat 9 March 23rd, 2009 12:53 PM
