2 Burner Camp Stoves - Page 2 - Defender Source
Go Back   Defender Source > Non-Technical Discussions > Cooking Corner
Join the Defender Source Community Today
Old September 20th, 2016, 10:09 AM
Originally Posted by javelinadave View Post
I'm shopping for something to use on some longer trips. I am leaning towards this:
https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER
Any experience good or bad?
What are you using?
I have that and can't say that I would recommend it. I haven't had any issues with it, but it is pretty cheaply made. My biggest complaint is that the lowest setting isn't low enough and the highest setting is pretty much unusable. I've had my cast iron griddle glowing red with that unit. I'm thinking of switching to a single burner and then just getting a grate to put over a fire.
Old September 20th, 2016, 05:22 PM
I have the Partner 2 burner - great quality, heat, etc...
the only issue with it is, its a pain to clean if stuff falls between the burners since the grid is welded in place and you basically have burners with open space in there.
that said - being open means you CAN clean it or just turn it over and dump out what ever fall in there, or power wash it inside and out...
I just bought a small 1 Burner Snowpeak for use with their gas canisters, has 2 legs with the canister forming the 3rd. The plan is that will be the solo camp cook rig or used for coffee and the like when the partner is in use.
95' D90 - daily driver..
Old September 20th, 2016, 06:51 PM
93' NAS 110- #234
Rob, seriously? The thing is a breeze to clean. The grill and burners pop out as one unit
Mark Kellgren
KM4BOR
Old September 20th, 2016, 06:54 PM
Huh? Really ?
Shit .... then I have been doing it the special way then..
Oops, I'll try it when I get her me from the beach
Old September 20th, 2016, 07:33 PM
Ignotus
gene
1960 109, w/200TDI
Being single I use a Snowpeak single for some cooking as it takes up less space and burns clean. Sometimes I use my Kelly Kettle if I just need to heat water for drinking or freeze dried meals(Mountain House, Backpackers Pantry, etc). I found an old Coleman 2 burner on Craaigslist for $10 which I refurbished for going with more than 1 person. On my motorcycle or bikepacking I use a MSR Whisperlight International multi fuel that way I can share fuel between the bike and the stove. That liter of unleaded for the stove once got me to a gas station!
Gene
1960 109
1960 88 Ignotus
Blog;
Old September 21st, 2016, 08:16 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Originally Posted by Overlander View Post
I approach my camping setup based on requirements. I find it a much better way to plan for equipment then the haphazard collection of random cool stuff, hoping it works.
for my collective kit, my requirement is in 15 min, from time I pull into a campsite in the dark, to have tent setup, cooking kit and food out, and burner on, ready to cook in 15 minutes total.
if you think about, on a typical weekend, car camping or overland trip, one usually leaves in the AM, drives all day with maybe some stops, and then usually pulls into a campsight in early evening between 5-7pm starving and ready to eat. if you get held up, or your pace ends up slower then expected, you may pull in after dark. KISS. Camping should not be alot of work. it sucks the fun and relaxation out of it.
This is similar to our thinking and our old Coleman 2 burner propane has done the job flawlessly. We enjoy cooking & will take the time to make nice meals while camping.... but we always have a couple of precooked (heat & serve) meals for late arrivals or after long hikes. Stews or curries are great for this.
Old September 22nd, 2016, 12:30 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
You get what you pay for. I borrowed that Everest stove you're looking at and it's just ok. Some of the cheaper stoves don't work well at lower settings so forget trying to simmer. I had the Snow Peak dual burner stove which I really liked by at 22,000 BTU's it flew through disposable canisters like there's no tomorrow. So I sold that one and bought a 22" partner cook stove and a propane canister. Support the fellas in Idaho and buy yourself an all American Cook Partner stove that will last several lifetimes.
Old September 22nd, 2016, 12:42 AM
I am a believer in the buy once, cry once theory so the price doesn't scare me with the Partner cookers. How long is the hose?
Old September 22nd, 2016, 01:09 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
I own eight camp stoves, including some ultra-expense Snow Peak models. Without a doubt, my #1 favorite of them all--my go-to stove--is my 1964 Coleman 413G, bought off eBay for $25.
It works at any temperature and has never let me down. Holds a ton of gas internally.
Here's mine making a pot of coffee at 5 degrees Fahrenheit in Northern Idaho in the winter:
1964 Coleman 413G by Chris, on Flickr
Steaks on the cast iron on a mountaintop in the Nevada desert:
1964 Coleman by Chris, on Flickr
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old September 22nd, 2016, 01:37 AM
chris snell
Chris Snell
87 Ex-MOD 110
Propane/butane stoves are absolutely worthless in sub-freezing temperatures. White gas works no-matter-what, is cheap and available at almost any small town convenience store, and easily stored in the MSR screw top bottles. One MSR bottle will last you quite a few meals. I like white gas stoves because they're so efficient that I can make slow-cooker dishes like pozole on it and not worry about running out of fuel.
Seriously, switching to white gas was a revolution for me for long-trip cooking.
2013 LR4
Old September 22nd, 2016, 07:36 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
If you're having problems simmering, add a heat diffuser to your cooking kit. Cheap & only takes up a tiny space. Just an example.
Those Partner Stoves look nice. Couldn't find a price or purchase option on their site.
Old September 22nd, 2016, 07:41 AM
I've thought about those, but they are just so damn big and space is at a premium in a D90 (as you know). Does anyone make a smaller white gas stove?
Old September 22nd, 2016, 07:44 AM
jafir's Avatar
jafir
Jafir Elkurd
The MSR dragonfly mentioned earlier is pretty small and will run on white gas.
Old September 22nd, 2016, 08:12 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Doesn't get much smaller than the Coleman until you look into a backpacking stove like a MSR or similar.
Old September 22nd, 2016, 08:47 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Optimus makes a single burner that looks nice but it's pricey.... about 180 on Amazon.
https://www.optimusstoves.com/us/us/...mus-hiker-plus
I would find space for the Coleman because two burners make cooking much more enjoyable unless you're just boiling water. Or combine the single burner with a folding grill for a fire then it might work for you.
Old September 22nd, 2016, 08:57 AM
I don't want a backpacking stove. I was thinking of just getting a single burner unit and getting one of those folding grates to put over a fire. I have a Jetboil for boiling water.
Old September 22nd, 2016, 10:02 AM
Davis's Avatar
Davis
Chris Davis
94 D90, 88 RRC
I second the coleman 2-burner white gas stove. We have two, one that lives in the drawer in the D90, and both over 10 years, maybe 20 years + old. I have had to maintain them a little, such as redoing where the adjustment knob goes in, but these just keep going and going and going...
Old September 22nd, 2016, 10:08 AM
My only concern about the white gas is carrying and storing it inside the vehicle.
Old September 22nd, 2016, 10:59 AM
Firemanshort's Avatar
Firemanshort
David Short
1980 Stage One 109
Some wrote earlier that bottle propane is useless in freezing weather.
I carry a single burner Coleman stove that screws on the top of a propane cylinder. It is the cheap $25 kind you buy at Walmart. I have carried it many places - including the Winter Romp. It has worked fine - even in the low single digit Romp temperatures. Renching and others on here have enjoyed a hot cuppa at lunch in the Maine woods from this propane fueled item and can vouch for my story.
All of that said - a 2 burner white gas or propane Coleman stove is the standard that all others are measured against.
Firemanshort
1980 Stage One 109
Sterling, VA
Old September 22nd, 2016, 11:09 AM
LR Max
Thomason, Max
1973 Series 3 109
I agree with Chris on compressed gas stoves not working at low temps. I learned that the hard way when it was 5F and my jetboil was not interested in working.
That said, 2 years ago camping out in Colorado. I had a borrowed propane two burner. Even though we were constantly concerned with running out of propane, we never really did. Lowest used temps was like, 55F. Worked great.
One thing with the coleman stoves, get some packing material to put between all of the bits. Helps prevent rattles.
Snow Peak Double Burner Stove Manimal For Sale - Parts 8 March 4th, 2016 05:33 PM
Partner Steel Stoves sonoronos Misc. Chit-Chat 20 October 14th, 2015 05:07 PM
3 Burner 30,000 ea. BTU Stove curry For Sale - Parts 3 September 5th, 2014 12:20 PM
Turner Burner Size Large bjf The Flea Market 43 February 13th, 2012 05:34 PM
Vermont Stoves gchinsr Misc. Chit-Chat 1 September 20th, 2011 08:26 AM
