Wiring? - Defender Source
Old September 2nd, 2011, 10:05 AM
JBinAlabama
john
Series 2A ..more parts on the way
Wiring?
I'm thinking that this truck will need a total rewire. Where do I go for a harness?
I did a mustang rebuild and used a painless kit. It was great,
Suggestions?
Old September 2nd, 2011, 02:45 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Suggestions?
http://www.autosparks.co.uk/index.php?cPath=59
Not cheap, but good.
Mike Hammond
Old September 2nd, 2011, 03:05 PM
dav1550
Dave Morgan
74 SIII 109sw / 00 SII
Used British wiring when doing the 109……It was like 4 harnesses as I recall, dash, engine, front and rear.
http://www.britishwiring.com/
Old September 2nd, 2011, 03:27 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
US: British Pacific, Rovers North, Roversdownsouth, British Wiring. UK: Auto Sparks, Craddock, LRseries, etc... .
Want to build it yourself you can use a painless wiring system.
Old September 2nd, 2011, 03:35 PM
JBinAlabama
john
Thanks guys! These look like a way better choice!
Old September 2nd, 2011, 04:43 PM
mikeslandrover
Mike Hammond
Glad to help
Mike Hammond
Old September 2nd, 2011, 06:10 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Unless you want to keep it original, just make your own.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old September 2nd, 2011, 06:53 PM
Ditto. lights starter genny gauges. Not much more to it. Even if you want the "original" thing you can still get the repro cotton covered wiring and the bullet terminals.
Please don't use that ghastly vinyl electrician's tape.
Old September 2nd, 2011, 08:31 PM
Albersj51
jason
1967 2a
Im making my own as well, using airplane wiring so it can't catch fire, relays and individual fuses for each circuit.
Old September 6th, 2011, 02:19 PM
djrover's Avatar
djrover
Dave Johnson
'91 RRC
There is another place i have used www.autowiringsolutions.com if you want a pre-built harness with fuseblock, etc. A fraction of the painless products.
_________________________
Dave J.
'91 RR Classic
'01 RR 4.6 HSE - Gone!
'00 Disco 2 - Gone!
'95 Disco 5-Spd - Gone!
'92 RR County SWB - Gone!
'63 2A SWB - Gone!
Old September 6th, 2011, 03:51 PM
When you buy a replacement harness from autosparks, british wiring etc, make sure to get PVC wrapped one AND I think the ones that have cloth over the top of the PVC look best and are worth the few extra $$$.
Also, make sure to get the exact right one for your truck.
Ron
Old September 7th, 2011, 08:14 AM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
Not a big fan of Painless products especially given the price. Also the original wiring on Land Rovers is nothing to write home about. You are far better off, imho to make your own using marine grade wire and connectors. This also allows you to tailor the wiring to any aftermarket upgrades that you have done or plan to do.
Old September 7th, 2011, 09:28 PM
JBinAlabama
john
WOW Guys!
I have never done any auto wiring.
I'm not really sure where to start!
I have traced down a few wiring issues in my Cobra which were caused by the salty air here.
But starting from zero sounds pretty involved......of course so was taking every nut and bolt part and bagging and tagging
Old September 8th, 2011, 03:34 AM
mikeslandrover
Mike Hammond
Suggestions?
It'll be simpler than the Mustang.
If you want a standard loom go autosparks. Total custom build it yourself - I just laid the wires out along the wings, body etc gave a foot extra at each end, cable tied it into a bundle and started adding connectors - all soldered, wrapped the loom with non adhesive pvc tape and never had any trouble with the loom.
Somewhere inbetween go auto sparks and add your own auxiliary looms for things like extra spot lights with relays, an extra fuse box etc.
Mike Hammond
Old September 12th, 2011, 03:40 PM
djrover's Avatar
djrover
Dave Johnson
'91 RRC
IF you really have no wiring experience and want a quick and easy approach, then order the standard replacement harness. Then disconnect the battery and cut all of your existing connections, leaving a few inches so you can make out the color of the wire. Use those remaining pieces as your guide when you connect your new harness. I re-wired my Series in about 2 hours this way..1 hour and 55 minutes to get the loom through the bulkhead and 5 minutes to connect all the ends.
Dave J.
'91 RR Classic
'00 Disco 2 - Gone!
'63 2A SWB - Gone!
Old September 12th, 2011, 03:57 PM
kevkon's Avatar
kevkon
kevin
Assuming that the wiring is original and correct
If you are up to the challange of doing your own wiring, there are many opportunities to correct deficiencies in the original LR electrical system as well as incorporate any additions. One extra bonus is that you will completely understand on of the most misunderstood areas of LR ownership when you are done.
Old September 12th, 2011, 04:27 PM
mikeslandrover
Mike Hammond
Or you could label, pull and unpick the old loom, correct any faults/replace dodgy wires, incorporate any upgrades and bind it all up again with the nonadhesive tape, then you'll really know your way round LR electrics.
That's more or less what I did on the 110, didn't want to run to a whole new loom when only one wire burned in one tiny spot. I rebound any worn areas. The sections running through the chassis were fine.
I added extra features as additional looms separate from the main loom with their own fuses etc.
Mike Hammond
Old September 12th, 2011, 06:06 PM
Also, fill all the bullets with dielectric grease when you fit them and replace any only ones that are even remotely suspect. I would also strongly recommend replacing the headlight pigtails.
Old September 13th, 2011, 01:03 PM
mikeslandrover
Mike Hammond
Yep, that'll make it bullet proof.
Mike Hammond
Old September 13th, 2011, 02:56 PM
Bullet proof and series land rover electric
wiring
Hella FF 1000's with wiring kit NIB Jammer 48 For Sale - Parts 0 August 15th, 2005 07:40 AM
In dash wiring? oldscratchggf Defender Technical Discussions 6 July 14th, 2005 11:26 AM
Some wiring Diagrams Mike Hippert Defender Technical Discussions 5 March 9th, 2005 11:14 PM
Wiring question - bypassing ECU for rear defogger dmarchand Defender Technical Discussions 8 September 30th, 2004 11:21 AM
