Who makes the large diameter Steering linkage? - Defender Source
Old September 12th, 2012, 02:52 PM
JBinAlabama
john
Series 2A ..more parts on the way
I have seen them on a few series trucks, but I have not seen them for sale!
Old September 12th, 2012, 03:01 PM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
do you mean these? :http://extreme4x4.co.uk/acatalog/DAN_BARS.html
OR
http://www.paddockspares.com/off-roa...ring-rods.html
Old September 12th, 2012, 04:04 PM
Denny at Hard Labor Creek also makes them... Here in GA.
Old September 12th, 2012, 04:12 PM
Sergeant_V's Avatar
Sergeant_V
Abel Villesca
1995 D-90 ST
Oliver Whiting at Overland Specialties has makes some for Defenders.
Old September 12th, 2012, 04:54 PM
1962siia88's Avatar
1962siia88
Daniel Rogers
1962siia88
Pretty easy to make yourself too. You can just cut the ends off so you have the female threaded side and find thicker tubing and weld the cut off ends into the new larger diameter tubing.
On my rig I went with GM 1 ton tie rod ends and .25" thick DOM tubing. I bought a DIY kit from Ruffstuff specialties. http://www.ruffstuffspecialties.com/...g/XOGMSTE.html
Good luck with it.
Daniel
Old September 12th, 2012, 05:00 PM
I love Dan bars.
Old September 12th, 2012, 05:06 PM
JBinAlabama
john
WOW!
how did I miss all this?
I did look
Since I'm adding the 200tdi, should I upgrade the drive shafts?
The old ones are toast.
The cost of this baby SURE is going up fast right now!
thanks for all the help guys!
Old September 12th, 2012, 09:37 PM
1962siia88's Avatar
1962siia88
Daniel Rogers
1962siia88
The early series u joints are the same as coiler (1300?) the later 2a and series 3 used the more common and bigger 1310(?) style. I'm going through this now as Im putting together my drive shafts.
You can tell the difference by the width of the yolks. The early series and coilers are about 3.25" wide and the later series yolks are 3.5" wide. The bearing caps for the u joints are the same size.
Daniel
Steering box adjustment, backlash, drag link ?s... wicks Defender Technical Discussions 27 May 28th, 2014 02:05 AM
Steering wheel adapters Buckon37s Defender Technical Discussions 109 July 1st, 2007 09:19 PM
Employment opportunity Rod Hayward Misc. Chit-Chat 18 December 20th, 2005 10:20 PM
Steering problem! TwisteD90 Defender Technical Discussions 3 June 2nd, 2005 02:55 AM
