Whining Noise at Low Speed - Defender Source
Old October 6th, 2011, 07:35 AM
The Dro
Dro
1988 Ninety
This has been bothering me since I got the truck and do not know if this is normal.
Every time I move the vehicle from a stop, I can hear whining. After the vehicle gets up to speed, the whining goes away. I cannot say exactly the speed, my speedo is not that great.
At first I thought that the T-Case and Tranny fluids were low. I flushed them both and topped them up... did not go away.
Any ideas? Normal?
Old October 6th, 2011, 08:12 AM
Probably a diff or tires.
Old October 6th, 2011, 09:36 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Sounds like the normal gear train noises to me.
Old October 6th, 2011, 10:55 AM
The Dro
Dro
1988 Ninety
I did the diffs too, moved from 235/70-15 to 235/85-16 and still the whining.
That's what I think too... But I want to be sure.
Old October 6th, 2011, 12:44 PM
grnrvrs's Avatar
grnrvrs
Paul
88
I've never had a problem with deer while driving my 88. Must be some of those normal drive train sounds.
1970 SIIA 88, Sold
Old October 6th, 2011, 01:34 PM
The Dro
Dro
1988 Ninety
Deers??? of Diffs?
Old October 6th, 2011, 04:31 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Deers??? of Diffs?
Deer as in those tasty 4 legged animals that like to wander across roads at dusk. They tend to run away from my 88, perhaps due to high pitched sounds that are 'normal'.
1970 SIIA 88, Sold
Old October 6th, 2011, 04:50 PM
The whining is probably just attributed to it missing its old owner, or the result of it being secluded from other Rovers. Very common issue associated with misuse of a great truck.
Old October 6th, 2011, 06:15 PM
The Dro
Dro
1988 Ninety
LMAO... I was expecting this.
Old October 6th, 2011, 11:10 PM
The Dro
Dro
1988 Ninety
WOW... I'm as slow as he IIA.
Old October 12th, 2011, 06:48 AM
The Dro
Dro
1988 Ninety
I drove the truck last night and the whining only happens when it 1st gear.
Old October 12th, 2011, 10:01 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
It's the tranny, probably a bronze bushing or slipped split ring that keeps the mainshaft gears tight. Mine did the same thing and was fixed after a quick rebuild.
Semper Fi!
Old October 12th, 2011, 10:05 AM
The Dro
Dro
1988 Ninety
Nice. Now I have to rebuild the tranny.
Where did you buy the kit from?
Old October 14th, 2011, 08:38 AM
Wolf Fabrication
Sterling Archer
'08 D3
Didn't buy a kit, bought a "new" tranny! Once I got my old one out I saw what the issue was. Either way, you can get most parts for those those trannys and they are the easiest ones to rebuild in my experience.
Semper Fi!
Old October 14th, 2011, 08:42 AM
Pedro
Get some earplugs
Later,
Dave
Old October 14th, 2011, 06:22 PM
kjva
Ken Jackson
1985 110 Wagon
In a Series if you can get all the gears and it does not jump out of gear going downhill the noise is just a Series being a Series in my opinion. On my 67 2A Wagon the squirrel cage drowns out any gear noise anyway.
Old October 14th, 2011, 06:31 PM
Wolf Fabrication
Sterling Archer
'08 D3
A healthy Series tranny should not whine
Semper Fi!
Tcase Noise in low with CDL locked Baldewin Defender Technical Discussions 1 July 9th, 2007 10:41 AM
Curious knocking noise mikeslandrover Defender Technical Discussions 6 March 29th, 2005 06:09 PM
whistling noise from engine jstrong98 Defender Technical Discussions 2 December 14th, 2004 11:37 PM
