Which Springs for a S3 109 CSW 200TDI? - Defender Source
Old April 24th, 2016, 07:48 PM
Robbiekb
Robbie Booth
2004 Discovery V8
hi all.
Continuing work on the drivability and overall utility of my 109 CSW.
I've ordered the 1 ton shackles and military extended bump stops to prevent the front dif from striking the crank pulley.
Now I need to address the Springs and Shocks on the car. They are currently very worn. In the front in particular, the springs are very flat.
So with the added weight of the 200tdi over the stock petrol engine plus the necessity to run the extended bump stops, I'm looking for a full set of springs and shocks.
The rear seems fairly straightforward. I was originally planning on running the Rocky Mountain 3 leaf parabolic rears with OME shocks.
For the front though, it's unclear to me if the 2 leaf parabolic spring will be stiff enough for the job. Can anyone advise on whether they've run the 2 leaf Parabolics on the front, and if so, what the results were ?
Cheers
Robbie
109, 200tdi, tdi
1985 LHD 110 CSW 200tdi broadstone For Sale - Vehicles 2 September 1st, 2012 11:33 AM
1983 110 CSW 200Tdi LHD Gkase For Sale - Vehicles 19 December 15th, 2011 08:34 PM
1984 200TDI 110 CSW (stratos blue) - $18,500 Jackie Treehorn For Sale - Vehicles 28 October 28th, 2011 12:46 AM
which tire? which carrier? raychel batts Defender Technical Discussions 9 January 8th, 2008 04:42 PM
Which Springs ? Hammertime Defender Technical Discussions 1 June 11th, 2007 05:15 PM
