Weird Indicator Fault - Defender Source
Old October 27th, 2014, 05:28 PM
Hache
Henry Lambert
1983 Ex-MOD 90 2.5N/A
On my ex-mod 90 my indicators/turn signals are behaving strangely.
The front right signal and repeater aren't working at all.
So when turning right, only the rear right signals flash. If I have the sidelights illuminated then the right sidelight flashes too (which is odd but suggests a bad earth).
When turning left, the two rear (right AND left) and front left signal and repeater flash.
I've checked the front two earthing points inside the wing and they look ok - no corrosion of dirt build up.
Tried replacing the flasher unit.
Also tested the repeater bulbs.
One of the rear fogs is missing a bulb but didn't think they'd be on the same circuit.
Any help greatly appreciated.
Thanks.
Indicator fault Peachy Support & Suggestions 4 October 22nd, 2013 02:20 PM
WTB: AT Shift Indicator fleabus Wanted 3 August 4th, 2006 04:46 PM
DX Indicator on Radio tron Defender Technical Discussions 5 April 20th, 2005 04:34 PM
Dash Indicator? DJ Menasco Defender Technical Discussions 9 September 11th, 2004 04:07 PM
indicator's rover4x4 Defender Technical Discussions 0 October 27th, 2003 03:02 PM
