Weber 2BBL Carb Set Up? - Defender Source
Old May 13th, 2012, 10:46 AM
texrover's Avatar
texrover
Jason
Anyone have any photos showing lines and hoses for the Weber 2bl set up?
I've got a cover for the filter with and without a hole at the top for a hose (assume for crankcase air)
What happens to the hose from the air cleaner?
Thx
Jason
Old May 13th, 2012, 11:05 AM
1962siia88's Avatar
1962siia88
Daniel Rogers
1962siia88
There are a few different version of that carb. I had the kind with the mechanical choke. If I understand your post correctly then you have a K&N style filter. I didn't have a hole in mine and eventually ditched the k&n in favor of this thing http://www.piercemanifolds.com/Photo...de=99217%2E090
Its a plenum that lets you use the stock oil bath filter. My truck liked it much better than the k&n. I dont remember my jetting anymore and sold the pierce manifold carb plenum setup when I decided to do my engine swap project. Sorry no pics. Pierce manifolds has a bunch of info on their site and generally were willing to help over the phone too.
Daniel
Old May 13th, 2012, 12:31 PM
texrover's Avatar
texrover
Jason
Thanks! I'll take a look at that; looks right. I've got the 32/36 DGV 5A
Old May 23rd, 2012, 03:46 AM
kullberg's Avatar
kullberg
Keven
1961
Daniel
Daniel
Thanks I was looking for just this part.
Keven
Old May 23rd, 2012, 11:01 PM
texrover's Avatar
texrover
Jason
Found that 'snorkel' air filter here:
http://www.carburetion.com/Weber/weberpartsair.asp
looks like a better deal than pierce website with more goodies.
great site btw for tuning the weber 2bbl
2003 RR L322
1971 Series IIA
1983 110 SW (Incoming)
1994 D90 ST (PO)
Old May 24th, 2012, 12:29 AM
kullberg's Avatar
kullberg
Keven
1961
I already ordered the Pierce last night.
I'll pull my old rusty oil bath air cleaner out, sand blast it, and powder coat it.
Now what color should it be?...Chrome?, Black, Red, Gun Metal gray? what do you think!
Old May 24th, 2012, 11:46 PM
texrover's Avatar
texrover
Jason
Black!
2003 RR L322
1971 Series IIA
1994 D90 ST (PO)
Old May 24th, 2012, 11:56 PM
kullberg's Avatar
kullberg
Keven
1961
Black!
I will take pic's tomorrow of the rusty air cleaner, I'll clean them and powder coat them and take finished pic's.
1 Vote for black
Old May 25th, 2012, 07:21 AM
texrover's Avatar
texrover
Jason
You doing the powder coating yourself?
If so, what are you using? I'm thinking of pulling the trigger on Eastwood's stuff but haven't looked at any competitive products.....
2003 RR L322
1971 Series IIA
1994 D90 ST (PO)
Old May 25th, 2012, 12:02 PM
kullberg's Avatar
kullberg
Keven
1961
Computer's Suck! I wrote you a long reply and it dumped it!
Yes I have a nice gun, but the one you get at Harbor Freight (HF) works pretty good, I use both Eastwood and HF powders, I would like to find better powders that don't fade.
I got an almost new oven on ebay 5-6 years ago, 6'h x 6'w x 4'd for about $2,700.00 Eastwood sells them for about $8,500.00, I got a good deal on ebay.
If you are doing small parts, just get an old kitchen oven and a HF gun and go for it.
Tip of the day; make sure your parts are CLEAN!
Old May 25th, 2012, 06:01 PM
texrover's Avatar
texrover
Jason
Yep that's the plan-small parts and no fancy oven!
2003 RR L322
1971 Series IIA
1994 D90 ST (PO)
Old May 25th, 2012, 07:42 PM
kullberg's Avatar
kullberg
Keven
1961
I don't have time this week, but as soon as I coat the parts I'll post them.
Have a great weekend.
Old June 4th, 2012, 01:44 AM
kullberg's Avatar
kullberg
Keven
1961
Well here you go, I went out back found my Air Cleaner, media blasted it, cleaned it, Powder coated it. I used Poly black and single stage Chrome with two coats of Clear.
When you Clear coat the single stage Chrome it turns it silver gray. here's some Pic's
Name:	Rusty Air Cleaner (640x480).jpg
ID:	52523   Click image for larger version
Name:	PC Air Cleaner (640x480) (1).jpg
Name:	Finished Air Cleaner.jpg
ID:	52525   Click image for larger version
Name:	Air Box & Cleaner.jpg
Old June 4th, 2012, 01:56 AM
kullberg's Avatar
kullberg
Keven
1961
Thx
Jason
I just rebuilt my weber today! I took some pic's before I took it off. and here is my new Air horn and my old Air Cleaner I just Powder coated.
Old June 4th, 2012, 10:13 AM
texrover's Avatar
texrover
Jason
Nice work!
I need to do the same (only I need to source an original air cleaner) and get the snorkel set up.
BTW, what size line from fuel pump to carb? What in line filter are you using?
Thanks again!
2003 RR L322
1971 Series IIA
1994 D90 ST (PO)
Old June 4th, 2012, 11:19 AM
kullberg's Avatar
kullberg
Keven
1961
Nice work!
Thanks again!
Mr. Rodgers above sent this link http://www.piercemanifolds.com/Photo...de=99217%2E090
If you look at the last picture it shows the part next to the Air Cleaner (AC) and the air tube from your AC will fit perfect. I used 1/4" to go over the hard plastic line and to the inlet of my fuel filter and then from the filter to the carb.
Old June 4th, 2012, 04:39 PM
1962siia88's Avatar
1962siia88
Daniel Rogers
1962siia88
Nice work!
Thanks again!
I've got a couple oil bath air cleaners if you need one.
Daniel.
Old June 4th, 2012, 11:05 PM
texrover's Avatar
texrover
Jason
Daniel.
I do; mine came with without one. Thx!
2003 RR L322
1971 Series IIA
1994 D90 ST (PO)
Old June 5th, 2012, 12:03 AM
1962siia88's Avatar
1962siia88
Daniel Rogers
1962siia88
Here is the air cleaner. Sorry to op for hijacking this thread. Anyone know how to post pics in a pm using forum runner?
Daniel
Old June 5th, 2012, 12:05 AM
texrover's Avatar
texrover
Jason
Daniel
Works for me! Thanks Daniel.
2003 RR L322
1971 Series IIA
1994 D90 ST (PO)
Edelbrock carb jet and rod set ups Chris Velardi Defender Technical Discussions 1 December 29th, 2011 11:21 PM
Weber carb 34 ICH manual choke for series IIA and III aka rover For Sale - Parts 0 December 13th, 2011 11:25 PM
OME HD Springs & OME Nitrocharger Shock Set Steve Friedman For Sale - Parts 1 January 24th, 2008 10:11 PM
FOR SALE - Set of Used Oil Cooler hoses / window studs eric_besore For Sale - Parts 10 August 31st, 2005 02:18 AM
Why Dual shock set up? sflash868 Defender Technical Discussions 11 February 28th, 2005 02:34 AM
