VIN question - Defender Source
Old August 16th, 2012, 12:35 PM
doscazadores
Vic Stull
none
VIN question
Been googling this but can't get the terms right, so thought someone here for sure would know the answer or can point me in the right direction.
Have my attention on a '94 D90 with a VIN that begins with SALDV . . .. I did a basic search and got advice that it is smog legal for 49 states except the one I live in, CA. How can I make sure this is accurate? And yes, I've tried to get through to CA's DMV. Waste of time it appears. Any help will be deeply appreciated.
Old August 16th, 2012, 12:50 PM
I think plenty of people have 93's and 94's in CA.
You don't have a VIN question at all ... you have a question about the legality of a 94 Land Rover defender in the state of CA.
Old August 16th, 2012, 12:58 PM
BCN's Avatar
BCN
BRIAN
94/D90/#1337/AA YELLOW
use this
http://www.bar.ca.gov/pubwebquery/ve...pubtstqry.aspx
or google "ca dmv smog history" and get the ca.gov site
94's are not a problem. Just reg'd mine but it was a CA car.
Old August 16th, 2012, 03:15 PM
doscazadores
Vic Stull
none
Thanks. And I might need to apologize for posting here? Appreciate the reply regardless of course!
Old August 16th, 2012, 04:47 PM
gravitysucks's Avatar
gravitysucks
Andy
94 D90
As long as its NAS, you shouldn't have any trouble registering it in any state including Ca. SALDV only tells you the country of origin (England), Manufacturer (LR), Model (Defender) and Series which NICB lists as Range Rover 100" wheel base. The other numbers/letters denote the body style, engine, transmission, year, assembly plant and sequence number with a check digit thrown into the mix.
If its salvaged or from out of state you'll probably have to get the VIN inspected, but that's a simple process.
Old August 16th, 2012, 04:58 PM
BCN's Avatar
BCN
BRIAN
Having just gone through it, shoot across any question. I'm sort of muddling my way through the ownership process and learning... the really hard way. Good luck!
Old August 16th, 2012, 07:49 PM
dont apologize .... you are free to post ... please ask questions ... buy a defender and become part of the elite! ;-)
Just so you know ... 99% of parts are obtainable apart from the roll cage and padding on a ST ( soft top ).
Fixing them is within the capability of a competent DIYer.
oh and post pictures when you get a truck ... everyone love a good land rover pic!
vin
Need Help: Odometer Question WCURoverD90 Defender Technical Discussions 6 August 5th, 2005 07:41 PM
VIN / frame question dave_lucas Defender Technical Discussions 6 June 30th, 2005 10:16 AM
Yet another Hardtop question sherpamike Defender Technical Discussions 2 August 15th, 2004 12:30 PM
