using synthetic rope with a Superwinch X9 - heat - Defender Source
Old March 8th, 2015, 02:49 PM
cdb
Clark Bowen
I have an X9 mounted on my RRC - with wire rope - and I bought synthetic rope from one of the site vendors before I read that X9s have a brake inside the drum which gets too hot for synthetics. So.....
Has anyone come up with some kind of shielding material to put around the drum to reduce the heat transmission enough to use synthetics?
2011 RR HSE -
2001 GMC 2500 4wd
Old March 8th, 2015, 03:09 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
I wouldn't worry about it, it's unlikely that you'll max the winch load under the most challenging expeditions to heat it that much. I'd worry more about that rope holding water and rusting your drum over the years.
Worse case it melts the last wrap...most don't get that deep on a spool and it seems unlikely to happen at all. The safety up side using a synthetic out weigh any concern, IMO. Good Luck.
Old March 8th, 2015, 03:11 PM
^ what he said.
I'm running synthetic with a Warn 10K, same drum issue (I believe). I covered the first stretch of the line with the "chaffing" sleeve and wrapped that on the first spool or so...hasn't been an issue so far.
Old March 8th, 2015, 03:14 PM
Bill Larson
Bill Larson
^ what he said.
yes that reminds me I need a few of those sleeves...thanks!! lol...
Old March 8th, 2015, 03:39 PM
aka rover's Avatar
aka rover
ed angel
95 D90
Chafe gear works good on the first layer , we use 3/4 or 1" on the 3/8 plasma line . You can get USA made chafe gear from Amazon for cheap . Brookstone if I recall .
If you want to know how warm your drum gets , simply remove your cable and run the winch for the manufactures listed line speed per minute .
So if you pull it in 100 ft timed one time you will probably be ok on temps , do that two to three times you might have a problem .
This only applies to winches that use the internal drum brake that you are over powering constantly always creating friction .
85 D110 3.5 3 DR
Old March 8th, 2015, 03:49 PM
I thought this was only an issue when spooling out under load. Unless I'm in a hurry, I always try to get enough line out to expose the last layer, for the most pulling power.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old March 8th, 2015, 03:51 PM
aka rover's Avatar
aka rover
ed angel
95 D90
You create a lot more heat spooling out but there is constant drag on the shoes in the drum creating heat buildup even while spooling in . Add mud rust to this and it's a bit more then on a new winch .
85 D110 3.5 3 DR
Old March 8th, 2015, 04:22 PM
cdb
Clark Bowen
One reason I asked was that I did melt the synthetic line on my Warn 9500. It got flat and melted looking but never broke.
I think the chafe sleeve is an excellent solution.
2011 RR HSE -
2001 GMC 2500 4wd
Old March 8th, 2015, 05:41 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
It's been my experience that all traditional synthetic lines look like that after use, regardless of brake configuration. When you think about the stresses involved on the drum and line compressing on itself it's not hard to see why.
Old March 8th, 2015, 05:50 PM
aka rover's Avatar
aka rover
ed angel
95 D90
If it's melted it won't massage back into flexible line . If it's compressed it will work back into shape with little effort .
85 D110 3.5 3 DR
Old March 8th, 2015, 05:54 PM
Can't go wrong with a couple of these 10' sections:
10' Replacement Synthetic Rope Abrasion and or Chafe Guard | eBay
Old March 8th, 2015, 06:03 PM
aka rover's Avatar
aka rover
ed angel
95 D90
Amazon has the same stuff for 12.95 and it's 30' that gives you enough to wrap lower drum and then a 20' piece for uv protection on the last wrap .
85 D110 3.5 3 DR
Old March 8th, 2015, 06:06 PM
I was trying to find that...where'd you scare it up on Amazon? I was finding 10' for $30, but may be looking in the wrong spot. I could probably use some more!
Old March 8th, 2015, 07:29 PM
aka rover's Avatar
aka rover
ed angel
95 D90
10 yards
85 D110 3.5 3 DR
winch
Synthetic winch rope Santiago Defender Technical Discussions 8 April 29th, 2008 08:56 PM
Synthetic rope users ??'s Buckon37s Defender Technical Discussions 12 February 10th, 2008 01:23 AM
line loc for synthetic rope, where to get? KevinNY Misc. Chit-Chat 6 January 23rd, 2006 04:46 PM
Which synthetic rope revisited: snuffer Defender Technical Discussions 0 June 14th, 2004 07:59 PM
Which synthetic winch rope is... howellm70 Defender Technical Discussions 17 May 31st, 2004 01:57 PM
