Ujoints on front drive shaft - Defender Source
Join the Defender Source Community Today
Old December 31st, 2014, 08:51 AM
airbornrover's Avatar
airbornrover
William Skidmore
1994 D90
Looked around here, Terriann, Lrfaq and G&R site. Couldnt find any definitive word on what brand of ujoint I should purchase locally, suggested by my friend Jarek. Problem is I purchased the Napa/precision 369 and it was a bugger to get the clips to fit and then found out that the threads were missing in the ujoint body after installing it.
Wanted to know what you guys think is the better brand to purchase. Ill be heading over to the auto parts store to show them the item is useless to get my money back.
The front drive shaft is from a late 70s- early 80s truck as far as I know.
Old December 31st, 2014, 09:27 AM
What vehicle are we talking about? Late 70's, early 80s is pretty vague.... A search will find all answers. There are only two sizes of u-joints ever used.
Old December 31st, 2014, 09:36 AM
will
u joints are either 3 5/16 cap to cap or 2 15/16 cap to cap. NAPA 369 and NAPA 344 I forget which is which. Those are the only two ever used and Rover bounced back and forth between the two a couple times. My 90 has one size on the front and the other on the back.
If the u joint has a hole that isn't threaded, it might be intended that you just cram the zerk fitting in there and the tapered thread cuts its way in? I've seen crazier shit in my (and your) time.
Originally Posted by airbornrover View Post
Looked around here, Terriann, Lrfaq and G&R site. Couldnt find any definitive word on what brand of ujoint I should purchase locally. Problem is I purchased the Napa/precision 369 and it was a bugger to get the clips to fit and then found out that the threads were missing in the ujoint body after installing it.
Old December 31st, 2014, 09:37 AM
Then there are plenty of aftermarket drive shafts out there using different sizes as well. Is it a genuine article or aftermarket?
Old December 31st, 2014, 09:53 AM
jafir's Avatar
jafir
Jafir Elkurd
Originally Posted by Ren Ching View Post
will
The 369 is the spicer 1310 style, and is the bigger one. It's a lot easier to find because lots of American stuff uses it.
the 344 is the 1300 style.
Old December 31st, 2014, 10:27 AM
airbornrover
William Skidmore
1994 D90
I hear what you are saying Ren Ching. But Jarek was pretty adamant about that not being the case, and it being a quality control issue with the product.
Do any of you know if one brand is better then the other, and if so which?
Old December 31st, 2014, 11:55 AM
jafir's Avatar
jafir
Jafir Elkurd
I think they are easier to service via the endcap, so I like the neapco joints better than precision. That's what I put in my D2 front shaft.
Old December 31st, 2014, 12:39 PM
The downside to the zirks in the end caps is that they are easily sheared off when wheeling in rocks (if you wheel it).
Originally Posted by pendy
I'm here for the D's
Old December 31st, 2014, 03:21 PM
airbornrover
William Skidmore
1994 D90
Correct. And I do.
Old December 31st, 2014, 03:47 PM
the rover shop
shayne young
They make a plug that goes into the end cap,.. Grease it up, remove the end cap and put the plug in and no worries, when you wanna regrease, just install the fitting again..job done..lubbly jubbly..
Old December 31st, 2014, 05:17 PM
Yup. They also make a little flat zero that uses a special fitting to grease it with
Old December 31st, 2014, 06:46 PM
Spicer's cost $12ea and hard to beat. Napa offered both a made in US and a made in Japan U joint last I bought one from them and the US made ones cost more and weren't as good.
Worldwide Land Rover Shipment and Importation Service
Bespoke Restoration & Modification work
Old August 21st, 2015, 10:09 PM
airbornrover
William Skidmore
1994 D90
Finally replaced the ujoints on front and rear driveshafts thanks to Jarek. I assisted on the first three then was the primary on the last one. The big bang from the 20ton press always catches you off guard, lol. Went with a Spicer ujoints and replaced two of the flanges which made things a lot easier. On the new flanges it seemed to us that the groove for the clip was bigger then the original ones.
Front Drive Shaft ron Wanted 5 July 1st, 2006 07:54 PM
Help! Question about front rotor and drive shaft. DesertRat Defender Technical Discussions 5 October 24th, 2005 06:14 AM
D11 front drive shaft jorge Defender Technical Discussions 3 April 12th, 2005 07:03 AM
New Type of Drive Rear Drive Shaft for D90? DJ Menasco Misc. Chit-Chat 18 July 19th, 2004 05:41 PM
front drive shaft jorge Defender Technical Discussions 6 December 9th, 2003 10:23 AM
