Trying to drop motor on new frame issue. - Defender Source
Old June 19th, 2016, 10:28 AM
Maineguide
Dan emidy
1972 series 3 88
Hello,
I am trying to put my motor back on the newer frame I have. My motor came out of a 72 88. The frame is a used one in good shape. It is from a 2a. I am having an issue with where the clutch slave is. It hits the crossmember below the motor and will not fall into place.
Does a 2a have a different crossmember? Any tips would be appreciated.
Old June 19th, 2016, 11:35 AM
ron's Avatar
ron
Ron
1994 NAS Defender 90
I don't know anything about series trucks but could it be a rhd vs lhd issue? was the same motor in the donor frame?
was frame modified?
do you have the old frame to compare?
good luck with your search
Old June 19th, 2016, 11:39 AM
Maineguide
Dan emidy
1972 series 3 88
I do not know if it was a rhd. The 72 is a lhd. I cut up the old frame and scrapped it. It appeard to be identical beforehand.
Old June 19th, 2016, 12:14 PM
SIII trams won't fit a IIa frame without cutting away some of the gusset on the engine crossmember. SIII had a different style gusset to clear the slave cylinder.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old June 19th, 2016, 12:19 PM
Maineguide
Dan emidy
1972 series 3 88
So should I cut it away ? Is it going to effect the strength of the frame much?
Old June 19th, 2016, 12:25 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Cut, yes
Effect strength, no
If you are worried, why not mount the IIA belhousing on the Series III transmission and use the IIA clutch release?
RDavisinVA
Old June 19th, 2016, 12:28 PM
Maineguide
Dan emidy
1972 series 3 88
I guess I could, but I don't have those parts. It was just a frame with differentials.
Old June 19th, 2016, 06:51 PM
While you are in there/shipfitters disease... , Im a fan of cutting the crossmenper out entirely and making it removable like the coilers. -Jeff
The big one under the bellhousing? Why?
Present:
1987 RRC- "Chewy 2"
Past:
motor
Battery Issue or Charging Issue? icnsltmfg Defender Technical Discussions 4 May 19th, 2016 01:25 PM
300TDI motor mount ears for NAS frame jaherring Defender Technical Discussions 8 July 6th, 2010 02:07 PM
Diesel motor with tranny still in frame... bitz For Sale - Parts 8 October 10th, 2008 04:18 AM
Well, I just wasted 2 hours trying to cheer myself up Hans Misc. Chit-Chat 10 November 21st, 2004 09:38 PM
Trying to re-locate a seat manufactuer.... Hans Misc. Chit-Chat 2 April 16th, 2004 02:47 AM
