Truck Stopped Running - Page 2 - Defender Source
Old August 5th, 2011, 12:35 AM
Albersj51
jason
1967 2a
if your oil smells like gas, it may be a good idea to change your oil so that you know it's not too thin.
Old August 6th, 2011, 03:45 PM
djrover's Avatar
djrover
Dave Johnson
'91 RRC
if it doesnt already have one, you may want to consider a cheap, see-through inline filter from your local parts store right before the carb - just to monitor the condition of the fuel...at least temporarily until you figure it out. I chased a similar intermittent problem for a long time and with a lot of parts. Put a glass filter in and started to see very fine sand like particles accumulating in the filter. Hole in the draw tube screen and a lot of crap at the bottom of the tank, occasionally blocking enough fuel to stall it. Good luck.
_________________________
Dave J.
'91 RR Classic
'01 RR 4.6 HSE - Gone!
'00 Disco 2 - Gone!
'95 Disco 5-Spd - Gone!
'92 RR County SWB - Gone!
'63 2A SWB - Gone!
Old August 6th, 2011, 08:18 PM
yeah, been there, had the glass filter, had the engine fire...didn't get the t-shirt.
though, I'm off petrol LR's these days.
Old August 15th, 2011, 08:40 AM
The Dro
Dro
1988 Ninety
Good and Bad News!!!
The good new is that I was able to replace my fuel pump, in-line filter and fuel hose. See pictures.
Drove the truck around town, did some errands and even attended the monthly club meeting, Charles even drove my truck.
The bad news is that something went very wrong with the electrical system...
When I was about to head back home, the hi-beam switch started smoking... Charles was seeing the lights dim and flicker. I was able to figure that the hi-beam foot switch was shorting.
Then something started to make a grinding noise and I could not figure what the hell what was the sound (I was driving at the moment). I shut the truck off and kept hearing it. Turns out it was the starter... Now the truck will not start with it. I was able to use the hand crank to start it.
Will see the extent of the damage when it stops raining.
ID:	41132   Click image for larger version
Old August 15th, 2011, 12:15 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Could the starter have remained engaged the last time you started the truck and then been spum considerably faster than it was designed to until it self destructed.
Pull the starter motor and have a look.
Don't forget to disconnect the battery first or you might end up doing some 12 volt arc welding.
Mike Hammond
Old August 15th, 2011, 01:05 PM
The Dro
Dro
1988 Ninety
That's my initial guess too. The book I have is not that great, I'm waiting for the "green Bible". Maybe the starter relay/solenoid burned with all the rushing current and the starter is OK. (wishful thinking $35 vs $300)
Once I stopped the truck, the starter ran for a minute or so... I was trying to get my tools out to disconnect the battery. But it was too late, the starter stopped on its own (or seize up).
When I turn the key to start the vehicle... nothing, not even a click. I was able to start the engine with the hand crank (got to love that).
Old August 15th, 2011, 05:07 PM
carlosz's Avatar
carlosz
Carlos
bump start can be your friend as well.... you frigging amateur.
let it roll forward down hill or a small incline, shift into second gear, turn ignition switch to "on".... as you have gathered speed you pop the clutch it wil jerk and then come to life... mash the throtle and keep on going nevr look back.
do I have to explain the facts of life as well as the birds and the bees too.
geez wiz
Old August 16th, 2011, 12:11 AM
The Dro
Dro
1988 Ninety
geez wiz
Funny you mention this... I told Charles that from now on I was parking at the top of the hill. LOL
To my luck the starter is fine. I by-passed the starter solenoid, hooked it directky to the battery and the truck started on the first try.
I will ne getting a new solenoid and will post back.
Old August 16th, 2011, 12:23 AM
mikeslandrover
Mike Hammond
Lucky you.
Mike Hammond
Old August 16th, 2011, 06:47 AM
The Dro
Dro
1988 Ninety
Lucky you.
I know
Old August 16th, 2011, 08:39 AM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
Before you install that new solonoid I would strongly recommend, if you have not done so already, that you make absolutely sure that there is not a short in the primary wiring or melted wire insulation that will become a short.
Old August 16th, 2011, 09:23 AM
carlosz's Avatar
carlosz
Carlos
Experience "The Land Rover Experience at your local Land Rover distributor".
now it makes sense what they mean by that slogan on those commercials, haa, haaaa...
Old August 16th, 2011, 11:16 AM
The Dro
Dro
1988 Ninety
Winter Project in Late Summer
Yes indeed. There's all sort off melting... I'm lucky that the truck did not burst into flames.
The high-beam lead wire was shorting and all hell broke loose. I've traced and replaced most of the melted wires.
I'm relocating the low/high-beam to a more dry/rust free area. I will change to a SPDT toggle switch on the dash.
I was planning to do the wiring as a Winter Project... Guess Santa came early this year and will be doing it as a Late Summer Project.
I guess that someone before me read this
http://www.mez.co.uk/lucas.html
Old August 22nd, 2011, 12:18 PM
The Dro
Dro
1988 Ninety
I'm picking up the new solenoid and will install it tonight.
Also, I found several wires melted and replaced all of the lamps wiring.
I'm hand-cranking the truck and been driving the truck around town... so far so good.
Thanks for the help/support.
Truck randomly dies... dlane Defender Technical Discussions 12 July 20th, 2011 12:23 PM
WTB: Running boards for D90 pmd Wanted 1 March 7th, 2006 08:07 PM
Want a Project Truck Brent Nevin Wanted 8 June 29th, 2005 02:28 PM
Got my truck running!!! Chris Cox Misc. Chit-Chat 2 April 4th, 2005 09:03 AM
Daytime running lights??? terreneuve Defender Technical Discussions 13 November 14th, 2003 10:22 PM
