Torrel disc brake kits - Defender Source
Old September 9th, 2015, 04:23 PM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
I've been trying to reach Jeremy at RMP, but I think he's pretty busy in the shop.
I was wondering if any one has installed one of these kits recently? I think I understand that this works with the original swivel ball housing, ie: I can rebuild the customer's leaking and pitted swivel balls and install the disc brakes when the kits become available again at some future date with only a little duplication of labor?
Appreciate any input!
Email is
Same place, new dogs.
Old September 9th, 2015, 04:52 PM
believe so but I don't think they use Land Rover brake parts
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old September 9th, 2015, 05:48 PM
Roverlab
Trevor Griffiths
Pads and calipers are GM, I think the rotor is also GM but had to be machined to fit? Maybe that was an earlier version....
I think there is a bracket for the caliper that mounts under or over the stub axle? I had 2 sets years ago and never got around to installing them, but I don't recall the set-up.
Email is
Old September 9th, 2015, 05:59 PM
Roverlab
Trevor Griffiths
Ok, I'll expand the query to include Zeus! Any Zeus users?
Email is
Old September 9th, 2015, 07:23 PM
kun109
matt kunert
1975 series III 109
If this is for a series, everything you need is included with the kit. The only modification I had to make, was to file down the oil filler plugs to clear the new caliper bolts.
Old September 10th, 2015, 02:49 AM
Greg S
Greg Sutfin
1986 90
Swivel balls are unchanged. You get a new swivel housing and can reinstall your existing front hub bearings or put new ones in. The kit is amazingly complete and Simple with a capital s April install. (And uses Chevy parts.)
A link to the complete installation manual is at www.vanislelandrovernetwork.com under the "LR tech info"
Old September 22nd, 2015, 11:34 AM
Tom109
Tom P.
1965 ExMoD 109, 1995 RRC LWB
Originally Posted by kun109 View Post
...only modification I had to make, was to file down the oil filler plugs to clear the new caliper bolts.
You can also swap the SPH from side-to-side, reversing the oil fill plug location so it does not foul. This did require SPH disassembly, but I was stripping/painting/rebuilding the whole axle anyway...
brake, kit
New disc brake conversion kits and more goodies Cube II Series Technical Discussions 15 May 25th, 2014 04:24 PM
Brake/Friction Pad (and maybe Brake Disc/Rotor) Replacement rijosho Defender Technical Discussions 62 March 16th, 2011 03:55 PM
Rear disc brake options kellymoe Defender Technical Discussions 44 April 9th, 2008 09:34 AM
Rear disc brake 110 Retrofit Defender Technical Discussions 23 May 15th, 2006 03:32 PM
3" BS and Disc Brake Protection Jay Defender Technical Discussions 0 November 27th, 2005 10:18 AM
