Tips on removing paint from small bits - Defender Source
Old September 1st, 2010, 01:20 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Anyone have any words of wisdom on removing paint off of small parts? I dont have a blaster.
I have been using aircraft stripper on the body in places and works well but I'm looking for a easy solution for small bits. The stripier I am using is very thick and requires scraping.
I'm hoping for....put it in a bucket overnight, and presto...clean parts!
Any recommendations?
Old September 1st, 2010, 01:22 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Plain old laquer thinner should do it.
Old September 1st, 2010, 01:28 PM
If they are steel, a wire wheel on a 4.5in angle grinder works well.
Old September 1st, 2010, 02:16 PM
D90user's Avatar
D90user
steve
That is my plan tonight... I have my doubts though. This paint is old, hard and old.
Jeff takes the cake!
I really don't have have that much to do. but thanks for the offer.
BTW I may be driving past your place this weekend, you planning on being around? I still have some parts to give back you.
Old September 1st, 2010, 07:24 PM
1962siia88's Avatar
1962siia88
Daniel Rogers
1962siia88
Steve
Have you tried Jasco. I've used it on body parts and it works well. Also thick but I would think submerging small parts in it would do the trick. It's also neutralized by water so pull out the parts and rinse them off. Good luck.
Daniel
Old September 1st, 2010, 07:31 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
I have seen tumblers for cleaning scale off steel so I think the idea would work for paint too.
Something like the vibrator/tumbler thing from Harbor Freight with some kind of media would probably work, but not tonight of course.
It works like this
Old September 1st, 2010, 07:43 PM
Easy off oven cleaner or a bucket of Red Devil drain cleaner. Soak over night. Washes off everything.
Old September 1st, 2010, 10:36 PM
D90user's Avatar
D90user
steve
Thats what I'm looking for! I cant believe it would but is there any issue with galvanized bits?
Old September 2nd, 2010, 12:17 AM
D90DRC
D Cantrell
1997 D90SW
I use A/C strippe, that will get about 90% off... Then ill finish the items off in the blast cabinet... A light surface profile will make the paint adhesion more effective...
But large items like axle housings.. Ill spray on some cheep lacquer thinner to loosen the paint up a bit, then hit it with my propane rosebud.... And same as the other parts I'll lightly hit it with my outside bead blaster....
I try to keep blasting down to a minimum, Its hard on the surface and glass media cost $$$
Still waiting for the Hope and Change to start
paint, vin
Removing paint from galvanized metal Hoosier Defender Technical Discussions 7 September 27th, 2009 01:51 PM
Paint Color/ Paint Code little black duck Defender Technical Discussions 3 March 16th, 2005 05:30 PM
Removing LE Checker plate - Need help removing killer adhesive JimC Defender Technical Discussions 4 December 6th, 2004 07:24 AM
Paint Code? Trigger Defender Technical Discussions 4 June 17th, 2004 01:45 PM
Paint a fiberglass hardtop? roverboy Defender Technical Discussions 5 December 12th, 2003 09:52 AM
