Surprise, my 1973 SIII Transfer box is stamped USA, WHY? - Defender Source
Old June 23rd, 2015, 10:02 AM
73S3BLIMEY's Avatar
73S3BLIMEY
Steve LaHue
1973 LR S3 88
Question Surprise, my 1973 SIII Transfer box is stamped USA, WHY?
When I pulled my Gearbox/Transfer Case I was surprised to see USA stamped in at least 2 places on the transfer case, on the bell housing, and on the gear box below the serial number. Were these made in the USA or just marked for the export vehicles? My second thought was a worry that it is some sort of hermaphrodite and good luck finding parts. SN ends in A.
Old June 25th, 2015, 12:18 AM
JohnBullsBollocks's Avatar
JohnBullsBollocks
Don
1963 IIA 109
That's a new one for me! The MOD would sometimes put XXXXX through a number and stamp a new suffix if the innards were changed over (such as the reverse bearing we discussed earlier). Yours is an "A" box based on the serial number, so it is an early SIII. That is consistent with the age of your vehicle. If the gearbox was rebuilt by Rover, they would attach a metal plate saying that it was refurbished. Many military SIII boxes have painted on serial numbers. I'll have to swing by and have a look sometime. I'm in Pleasant Valley almost every day. The only real difference between home market (RHD) gearboxes and LHD vehicles was the gear lever. Bent a bit different for RHD. PM me and we can exchange phone numbers if you want.
97, siii
1973 Series III 88" Station Wagon :: 1973 Land Rover Series 3, 88" xjahx Defender & Series Truck Registry 0 June 21st, 2015 11:52 AM
VIN Issue: VIN Stamped on wrong spring hanger MN_Vagabond Defender Technical Discussions 14 April 3rd, 2015 12:09 PM
Why oh why (aka broken CV joint) bharris Defender Technical Discussions 39 January 22nd, 2008 12:08 AM
WHY WHY WHY am I blowing through suspension bushings? KevinNY Defender Technical Discussions 27 September 13th, 2007 02:29 PM
